Rigid - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 04-28-2010, 10:08 AM Thread Starter
hillbilly's Avatar
Rigid
i wanna drop my bike and makeing it a rigid would it be the easyest? would i have to get a longer drive shaft ?
hillbilly is offline
post #2 of 9 (permalink) Old 04-28-2010, 11:08 AM
No need to mess with the drive shaft.
I have seen those strats made from tubing and then welding a nut on each end.
post #3 of 9 (permalink) Old 04-28-2010, 12:48 PM Thread Starter
hillbilly's Avatar
thats all i needed to know thanks man
If It's Got Wheels I Can Drive It
If It's Got Hair I Can Ride It
K and N Pods
12 inch Aps
Handle Grips
Dual Break Lines
House Of Colors Candy Apple Red
Lowered
Road Pegs
Jetted
Coasters
Custom Exhaust
Red Plug Wires
Neons
Custom Switch Panels
Harley Turn Signals(Coming UPS)
Red Hoses
Removed Tach
Removed Speedometer
post #4 of 9 (permalink) Old 04-28-2010, 02:00 PM
I now know two things according to your sig. line,You are a fan of The Cowboy Way and if it has feet you can't dance with it
post #5 of 9 (permalink) Old 04-28-2010, 02:05 PM
I was afraid some comments like this were coming up. I will keep my thoughts to my self.
post #6 of 9 (permalink) Old 04-28-2010, 03:30 PM
i am currently building a rigid bobber on below thread if you would like to follow it, hopefully it will answer most of your questions.
https://www.vn750.com/forum/showthread.php?t=14376
Harley sportster fenders
custom raked front end
custom exhaust
vn800 tank and guages
modified seat and recovered
rear frame chopped
custom wiring harness
airbox removed
hzhardy is offline
post #7 of 9 (permalink) Old 04-28-2010, 03:37 PM
dirtrack650's Avatar
If I were doing a strut rear end, would square tube be better? How about square bar?
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #8 of 9 (permalink) Old 04-28-2010, 03:40 PM
I am using swedged rods and heims so i can adjust my ride hieght
custom exhaust
rear frame chopped
airbox removed
hzhardy is offline
post #9 of 9 (permalink) Old 04-28-2010, 07:07 PM
the best way to do a rigid is to do luck Scoot did, and cut the frame and weld in tubes to replace them... a longer driveshaft is not needed as long as you keep the stock length wheel base. If you want to stretch the rear, then yes you need a longer driveshaft. If you have decent welding skills, building a longer driveshaft isn't hard...search ebay and buy a second drive shaft, cut them both down to frankienstine one shaft to the other. I can get you more info on this from a chopper forum i subscribe to if you decide to go this way... and btw, a brand new bike builder and welder made a longer shaft for a Honda Nighthawlk that looks wicked sic and is very durable.
