Tire pressure - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 03-28-2010, 09:30 PM Thread Starter
Tire pressure
I have a question. I don't actually need the answer, as I already have the right answer for me, but this came up on another forum, and there is a bit of a controversy about. it. Say you have a bike, car, truck, whatever, and it no longer has the stock tires on it, they have been replaced with another brand. Most vehicles say in the owners manual and on the vehicle what the tire pressure should be. But remember, these are not the original tires. Should you use what is shown in the vehicle manual and on the vehicle itself, or should you go by what the tire manufacturer put on the tire sidewall? I need some opinions. Thanks, Jerry.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #2 of 13 (permalink) Old 03-28-2010, 09:58 PM
cm4cm5's Avatar
i myself go by the tires at first, ill adjust the pressure as the tires wears so i can get the best life span out of them. and of course proper maintenance on the vehicle, and on the tires, plays i big part in it too.
Jeff Brooks
Owensboro KY
'94 Vulcan 750
cm4cm5 is offline
post #3 of 13 (permalink) Old 03-28-2010, 10:09 PM
cm4cm5's Avatar
OH...and dont forget, larger vehicles, such as trucks, have 5 tires, not 4. yes, my spare tire is in my rotation of tires. dont want to be stuck with a flat, dry rotted spare on the side of the road. yea..been there, done that, not fun.. of course that was before cell phones. lesson learned the fist time.
Jeff Brooks
Owensboro KY
'94 Vulcan 750
cm4cm5 is offline
post #4 of 13 (permalink) Old 03-28-2010, 10:59 PM
dirtrack650's Avatar
I run a few pounds under the rated max pressure on the tires, not the book.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #5 of 13 (permalink) Old 03-28-2010, 11:01 PM
I go by the weight of the vehicle. More weight more air pressure.
post #6 of 13 (permalink) Old 03-28-2010, 11:30 PM
KIMMERLING's Avatar
Bikers garage told me to do 36 in the front 38 in the back. I have metzler 880's. Fort Worth, Texas....
Ventura guards
MadStadt mount
Givi windshield/Heated grips
Backoff
Riderbeads
Givi 52 topcase
OEM centerstand
Headlight modulator
Battery tender
KIMMERLING is offline
post #7 of 13 (permalink) Old 03-28-2010, 11:32 PM
KIMMERLING's Avatar
I bought the dial in air compressor. You just attach it to the tire...it digitally shows the pressure..you turn the knob to the number you want and hit the button. It stops when adequate air pressure is achieved. Then detach and go!
Ventura guards
MadStadt mount
Backoff
Riderbeads
Givi 52 topcase
OEM centerstand
Headlight modulator
Battery tender
post #8 of 13 (permalink) Old 03-29-2010, 12:08 PM
cglennon's Avatar
Originally Posted by VN750Rider/Jerry View Post
...Should you use what is shown in the vehicle manual and on the vehicle itself, or should you go by what the tire manufacturer put on the tire sidewall? I need some opinions. Thanks, Jerry.
Personally I do neither.
For after market tires (i.e., not OEM) I refer to the tire manufacturer recommendation for my specific vehicle. It is my understanding that max tire pressure printed on the sidewall is just that, a max. for the tire regardless of application and that tire pressure should be set according to load, vehicle design, handling characteristics, etc., etc.. However, some tire manufacturers list a generic pressure for a group of vehicles (which may or may not be the max printed on the sidewall). In this case I use both the manufacturer recommendation and owner's manual, IF the owner's manual lists separate pressure for each axle as follows;
1. Cross out the highest tire pressure listed in the owner's manual and replace it with the tire manufacturer's generic number.
2. Calculate the lowest tire pressure percentage (based on the original OEM tire pressure). This is usually just a few pounds difference
Of course, I skip the above entirely if I have a tire dealer who knows their stuff and can recommend the right pressure for my vehicle.
Chris Glennon - Portland, OR
cglennon is offline
post #9 of 13 (permalink) Old 03-29-2010, 01:26 PM
Chavisimo's Avatar
I go by the specs on the tire.
VROC Number: 31246
2003 Kawasaki VN750 SOLD
2006 Honda VTX1800C
Chavisimo is offline
post #10 of 13 (permalink) Old 03-29-2010, 02:27 PM
fergy's Avatar
Some of the tire mfg websites have charts and will state recommended pressures for each bike, but I think with everyone's weight and gear being different, it seems like the pressure needs to be somewhere in between the bike maker's specs and the tire mfg specs. Only solid rule I can think of is never exceed the max psi listed on the sidewall of the tire, and you're probably not going to need quite that much in the tire.
I typically use the sidewall psi stamp as a basis to calculate what should be in the tire, according to the weight of the bike, my weight and approximately what my accessories weigh. Then I add a few lbs to make sure I'm above that number, and usually I'm getting within a few lbs of the max psi on the tires.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
