REAR AXLE - need longer one for lowering kits - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 19 (permalink) Old 03-24-2010, 03:41 PM Thread Starter
letitflight's Avatar
Howdy!!
I need some help here, plzzz
A few month ago i bought the "lowering kits" from a guy on Ebay. He used the blueprint from VN750.com to built them.
Since then i have been looking around for a longer rear axle (at least 1/2 inch longer) so i can finally install them.
NOWHERE to find them, or maybe i am not really sure what to look for
Anyway, I would offer you some cash (through Paypal) if you can find the right axle for me.
Maybe one of you knows exactly where to find one.
thanks in advance
PEACE!!!
2005 Vulcan 750
letitflight is offline
post #2 of 19 (permalink) Old 03-24-2010, 08:30 PM
I don't know anyone that makes a longer axle for the Vulcan. Odds seem to say it is possible some bike somewhere has an axle you could use instead that would fit and give you the needed clearence, but no one to my knowledge has posted this info.
But all it not lost, as any well equipped machine shop should be able to make you up one if you have the green to toss at them. Out of all the complex items one can have machined...a simple threaded rod is perhaps the easiest.
Call around town. You likely will have to bring in the stock one for comparison measurements, but I can't see this running you more than 60-70 bucks.
post #3 of 19 (permalink) Old 03-24-2010, 09:12 PM
Have you done a search here?? Some one here got one instead of grinding the swing arm, I can't remember whom. Try florida man. Floman.
post #4 of 19 (permalink) Old 03-24-2010, 09:52 PM
I have been research the VN1500 as a posible source of a rear axle, some years and models use the same bearings as our VN750, the thing is I can't find the specs for length... now there is another way of dropping the back while still using those brackets. You need to have the Axle Hole reamed out to 1 1/4" to 1 3/16" dia x 1/8" deep. Then find a 5/8" shock bushing for a car and remove the metal bushing cut the bushing to a few thousandths of an inch less than 1/8" and drill out the Axle Hole center to make a pressed bushing. Then you need to cut your castle nut in Half and weld a washer onto the back side. Like I said its complicated, but it is safer than trying to grind down swing arms, and is a lot cheaper than a new axle... the Shock busing is only $2.50 for 2 from Napa. I am not sure how much the Machine work would cost, because I had mine built with the recesses in already.
post #5 of 19 (permalink) Old 03-24-2010, 09:56 PM
here is a long long discusson on the axle dilema.
https://www.vn750.com/forum/showthrea...=lowering+axle
post #6 of 19 (permalink) Old 03-24-2010, 10:09 PM
how thick are your Lowering brackets niterider?
post #7 of 19 (permalink) Old 03-24-2010, 10:12 PM
I want to say 1/4 in. Yea 1/4 in.
post #8 of 19 (permalink) Old 03-24-2010, 10:15 PM
The Professor
lance328's Avatar
Originally Posted by letitflight View Post
Howdy!!
thanks in advance
Wkrizan had one for sale a 1/2" longer, did you contact him?
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #9 of 19 (permalink) Old 03-24-2010, 10:20 PM
I was just wondering because it doesn't look like 1/4 in the pictures you posted.
post #10 of 19 (permalink) Old 03-24-2010, 10:25 PM
I will have to take measurement to be sure.
