lowering the ass end - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 03-16-2010, 05:34 PM Thread Starter
justjim910's Avatar
so i want to lower the ass end but dont really want to make it rigid, is saw some mini springs on a bike some where but am having trouble finding them for my bike (89 vn 750) anyone know where i might should look?
her name is lucille and she's all mine
justjim910 is offline
post #2 of 12 (permalink) Old 03-16-2010, 06:23 PM
there are several ways to lower the back of the VN7XX, the most common is to get a set of Harley Davidson 10.5" shocks. Another Way is to make shock relocation brackets and run the stock shocks.
post #3 of 12 (permalink) Old 03-17-2010, 08:53 AM
BMan23777's Avatar
I made the brackets!!!! It's alot of work!!! I'm going with the harley lowering shocks this year though cause my shocks are shot!!!!
Brian Manchester
'89 "GRIMM"
04 durango AWD
BMan23777 is offline
post #4 of 12 (permalink) Old 03-17-2010, 09:30 AM
On His Lady Vulcan
wkrizan's Avatar
OOOOOhhhhhhhh....He said Ass!!!!
Pictures of the "Ladies"
wkrizan is offline
post #5 of 12 (permalink) Old 03-17-2010, 09:44 AM
Would these be the correct ones?
http://cgi.ebay.com/ebaymotors/BURLY...Q5fAccessories
Whats the difference between these and the progressive struts?
1992 Vulcan 750.
Ear shaved and re-jetted.
theone2043 is offline
post #6 of 12 (permalink) Old 03-17-2010, 12:05 PM
letitflight's Avatar
i have a set of lowering brackets, i am not sure if the rear axle is long enough though....how did you get yours to fit?
thanks!
PEACE!!!
2005 Vulcan 750
letitflight is offline
post #7 of 12 (permalink) Old 03-17-2010, 01:03 PM
On His Lady Vulcan
wkrizan's Avatar
thanks!
I found a 1/2" longer axle and my local bone yard. I still have it and no longer using it if youre interested in buying it.
wkrizan is offline
post #8 of 12 (permalink) Old 03-17-2010, 01:24 PM
PM Sent
PEACE!!!
2005 Vulcan 750
post #9 of 12 (permalink) Old 03-19-2010, 05:36 PM
I have a solution for the axle problem when using the lowering brackets... go to the local parts store and get a shock busing kit that has a metal busing with an inside diameter of 16mm (5/8"), a piece of 16mm (5/8") All Thread, then have them measure the OD of the Busing (keep this info for later),a piece of 16mm (5/8") All Thread, and 2 16mm (5/8)nuts and washers. Drill a bore hole of recorded Bushing OD, then drill a 1 1/16" (that is one and one-sixteenth inches) hole 1/8" into the shock lowering bracket. Take the The all Thread and screw on one nut with and one washer down far enough to slide the metal bushing with enough threads exposed to put the second washer and nut on. Tighten the nuts down as tight as possible, measure 3/16" and cut the bushing with a hacksaw, dremal, or other cutting tool. Sand the 3/16 bushing down to 1/8". (Do the same process for the other side, One shock bushing will make two axle bushings.)
Next Press the bushings into the Lowering Bracket Axle hole. Install Bracket, torque nuts to required specs. Viola Problem solved... (it is not necessary to have the All Thread if you have access to a way to hold the bushing square while you cut it)
post #10 of 12 (permalink) Old 03-20-2010, 10:43 PM
nOObbobber's Avatar
My vote goes for progressives as the easiest way to lower the "rear end"... I bought some and they are nice... plus easy install.
http://profile.imageshack.us/user/Fester42
1994 VN750
Tins/Head lamp - flat black
Front fender ditched
Rear fender bobbed
Powder coated rims
Recovered seat
Progressive 11.5" shocks
Progressive fork springs
Jardine "rumbler" exhaust - wrapped
Relocated horn
12" Z-bar ape hangers
Motion Pro Throttle Cables
Venom 110/90-19 170/80-15
Side mount License Plate/ Brake Light
Aftermarket signals
Speedo - Acewell
nOObbobber is offline
