Front Brakes! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 15 (permalink) Old 10-29-2009, 05:19 PM Thread Starter
Front Brakes!
I replaced the lines on my 85 700... Got fluid too come out of the calipers... But handle dosent give pressure less you pump it.. Anyone know what this might be?
timqueen1987 is offline
post #2 of 15 (permalink) Old 10-29-2009, 05:34 PM
The Professor
lance328's Avatar
You have air in the system, you need to bleed it out.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 15 (permalink) Old 10-29-2009, 05:49 PM
On His Lady Vulcan
wkrizan's Avatar
Well he is from Kentucky
Pictures of the "Ladies"
wkrizan is offline
post #4 of 15 (permalink) Old 10-29-2009, 06:08 PM
Simple Solutions
seebeeare's Avatar
not nice ...
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
post #5 of 15 (permalink) Old 10-29-2009, 06:12 PM
On His Lady Vulcan
wkrizan's Avatar
No it wasn't, I apologize. It's just that when one owns an '85 they aught to have some mechanical skills and bleeding brakes is the most basics, my 17yr daughter knows that. Hard luv man, HARD LUV!!!
wkrizan is offline
post #6 of 15 (permalink) Old 10-29-2009, 06:14 PM
Simple Solutions
seebeeare's Avatar
no it wasn't, i apologize. It's just that when one owns an '85 they aught to have some mechanical skills and bleeding brakes is the most basics, my 17yr daughter knows that. Hard luv man, hard luv!!!
rofl
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
post #7 of 15 (permalink) Old 10-29-2009, 06:22 PM
STUMPYSKAW's Avatar
Dumb ?
Hey seebeeare whats rofl stand for? I can't figure that one out, maybee it's becuase I have an 85 VN700 and from Missouri.
"DAISY" 85 VN 700 19K
Owned since 09/12/09
Done list
Metal radiator drain plug
Removed exhaust baffles
TOCMAN. ACCT's
VN900 Seat
TO Do list
To much to list
VN900 seat on my VN700
https://www.vn750.com/forum/showthread.php?t=12903
Debaffling my stock pipes
https://www.vn750.com/forum/showthread.php?t=12756
STUMPYSKAW is offline
post #8 of 15 (permalink) Old 10-29-2009, 06:35 PM Thread Starter
ROlling on floor Laughing.. So it is still air in the system? Guess it is backk too bleeding.. Think I have been through about a whole thing brake fluid.. I am gonna just not read the from kentucky part.. lol.
post #9 of 15 (permalink) Old 10-29-2009, 07:01 PM
Simple Solutions
seebeeare's Avatar
air can get trapped in a couple of spots and are u positive there is no leaks anywhere .. make it a point to not not barry the lever when u let the air out of the bleeder and make sure that the bleeder is all the way tight befor letting up ...
if u attach an aqaurium tube or oxygen tube tube u can see the air bubbles come out of the bleeder ...
i try and not let the master get below half. any air from the top will make u start all over again ... they make the speedy bleeders and vac pumps to assist in the bleeding process... take your time; i dunno bout u but i like havin workin brakes ... did u replace your pads too ... did u check the calipers for a good seal at the pistons also check for pitting and it may needto be rebuilt ... ( orings and pitting is hell in a high pressure hydrolic sytem ... they can deteriorate after time ..) and a little honing... if the bike sat for a long time and there's pitting in there and u pushed the caliper all the way back
good luck and keep us posted ...
I may have gone into more detail then needed but just a couple things u may want to look at...
if all u replaces was the hoses id check all the connections for good seals ... no brake fluid drips anywhere ?? or a bleeder not gettin set all the way ...
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
post #10 of 15 (permalink) Old 10-29-2009, 07:19 PM
STUMPYSKAW's Avatar
"rofl" learn somthn new every day. Thanks.
X2 on seebeeare's info, Double check everything, did the brakes work before you changed the lines?
Done list
TOCMAN. ACCT's
VN900 Seat
TO Do list
To much to list
