New tire installation problem/question? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 08-28-2009, 07:54 PM Thread Starter
So I got an oversized 170/80 15 and took it to the tire shop to get mounted today and they spent 45 mins on it and said they couldnt get it to bead up.
Anyway they finally did - but my question is - should I worry about it blowing out on the road or anything - or should I be good? I am just nervous cuz I heard like a loud air pop about 5 or 6 times as they were trying to do it.
________
Nexium class action lawsuit
MisterPister is offline
post #2 of 7 (permalink) Old 08-28-2009, 08:16 PM
Simple Solutions
seebeeare's Avatar
the guy at the shop that couldnt get it to beed must not go a lot of tires your tire will be fne on that rim... i dont know the specifics, but 20mm wider tire isnt gonna change to the next level of rim size, ive ran over and under a 1/2 inch on car tires for entire lifes of the tire... if its not perfect it will be close enough ...
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
post #3 of 7 (permalink) Old 08-28-2009, 08:25 PM
The air pressure keeps the bead from unseating. It will be fine.
post #4 of 7 (permalink) Old 08-28-2009, 08:38 PM Thread Starter
while you guys are here - do you know the foot pound pressure for reinstallation of front wheel?
________
Hawaii Medical Marijuana
post #5 of 7 (permalink) Old 08-28-2009, 08:55 PM
Simple Solutions
seebeeare's Avatar
torqu spec for the axel nut ? i use the german torque spec gooodntight.... or air pressure ? i think i run betwwen 32 and 40 been a while since i checked the pressure i usually look at the how the tread looks on the pavement...
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
post #6 of 7 (permalink) Old 08-28-2009, 09:07 PM Thread Starter
sorry I mean torque pressure on axle nut and pinch nut
________
Percocet Not Working Anymore
post #7 of 7 (permalink) Old 08-28-2009, 09:14 PM
I think the pinch bolts are 10 ftlbs and the axle nut is 45...but don't take my word on it..
Whatta mean you don't have a service manual ???
LOL
Standard Torque table (* = this is a Standard Fastener Torque)
These dimensions are the sizes of the bolt/screw,
NOT the size of the tool to fit the nut/bolt head.
5 mm = 30- 34 in-lb* (> 3/16")
6 mm = 52- 69 in-lb* (< 1/4")
8 mm = 10- 13 ft-lb* (= 5/16")
10 mm = 19- 25 ft-lb* (< 7/16")
12 mm = 33- 45 ft-lb* (< 1/2")
14 mm = 54- 72 ft-lb* (< 9/16")
16 mm = 83-115 ft-lb* (> 5/8")
18 mm = 125-165 ft-lb* (< 3/4")
20 mm = 165-240 ft-lb* (< 13/16")
NOTE: to convert in-lb to ft-lb, divide by 12 (Ex: 60 in-lb = 5 ft-lb)
to convert ft-lb to in-lb, multiply by 12 (Ex: 8 ft-lb = 96 in-lb)
Most of these torque values are from the Clymer Service Manual
If you find errors or have values not listed, email "doowriter123", and I will update the file.
Tightening Torques
BRAKES:
Rear brake pedal pinch bolt . . . . 18 ft-lb
Disc bolts . . . . . . . . . . . . . 16.5 ft-lb
Front banjo bolts (ALL) . . . . . . 18 ft-lb
Front caliper bleed valve . . . . . 5.8 ft-lb
Front caliper mounting bolts . . . . 24 ft-lb
Rear brake arm bolt . . . . . . . . 13.5 ft-lb
CLUTCH / TRANSMISSION:
Clutch lock nut . . . . . . . . . . 96 ft-lb
Clutch spring (pressure plate) bolts 80 in-lb = 6.7 ft-lb
Damper cam nut . . . . . . . . . . . 89 ft-lb
COOLING SYSTEM:
Cylinder drain plugs . . . . . . . . 78 in-lb = 6.5 ft-lb
Radiator drain plug . . . . . . . . 26 in-lb = 2.2 ft-lb
Radiator mounting bolts . . . . . . 52-69 in-lb*
Thermostat housing bleed valve . . . 69 in-lb = 5.7 ft-lb
ELECTRICAL:
Rectifier/Regulator bolts . . . . . 60 in-lb = 5 ft-lb
Starter one-way clutch Allen bolts . 25 ft-lb
Stator mounting bolts . . . . . . . 52-69 in-lb*
Rotor mounting bolt . . . . . . . . 33-45 ft-lb*
ENGINE:
Balance bolts - left & right . . . . 51 ft-lb
Camshaft bearing cap bolts . . . . . 8.5 ft-lb
Chain guide bolts, upper . . . . . . 17.5 ft-lb
Chain guide tentioner bolts, upper . 11 ft-lb
Connecting rod cap nuts . . . . . . 34 ft-lb
Cylinder block nuts . . . . . . . . 18 ft-lb
Cylinder head cover bolts . . . . . 87 in-lb = 7.3 ft-lb
Cylinder head bolts . . . . . . . . 8.5 ft-lb
Cylinder head to crankcase stud nuts:
6mm preliminary . 61 in-lb = 5 ft-lb
6mm final . 11 ft-lb
10mm preliminary . 18 ft-lb
10mm final . 29 ft-lb
Cylinder head to cylinder nuts:
6mm preliminary . 78 in-lb = 6.5 ft-lb
8mm preliminary . 13 ft-lb
8mm final . 18 ft-lb
Engine coolant drain plugs . . . . . 78 in-lb = 6.5 ft-lb
Neutral switch . . . . . . . . . . . 19-25 ft-lb*
Oil drain plug - bottom . . . . . . 13 ft-lb
Oil screen/drain plug - side . . . . 13 ft-lb
Oil filter . . . . . . . . . . . . . 13 ft-lb
Oil line - external bolt . . . . . . 8.5 ft-lb
Oil pressure switch . . . . . . . . 11 ft-lb
Oil pressure switch bolt . . . . . . 14.5 ft-lb
Primary drive gear bolt . . . . . . 89 ft-lb
Reed valve cover bolts . . . . . . . 60 in-lb = 5 ft-lb
Shift lever pinch bolt . . . . . . . 60 in-lb = 5 ft-lb
Spark plugs . . . . . . . . . . . . 12 ft-lb
Spark plug retainer . . . . . . . . 8.5 ft-lb
EXHAUST:
Exhaust manifold cap nuts . . . . . 18 ft-lb
Muffler mount bolt & nut . . . . . . 11 ft-lb
FRAME:
Sub-frame front & rear bolts . . . . 33 ft-lb
Frame front cross-brace bolts . . . 10-13.5 ft-lb*
Seat mount bolts . . . . . . . . . . 52-69 in-lb*
Sidestand nut . . . . . . . . . . . 10-13.5 ft-lb*
FUEL SYSTEM:
Air filter cover screws . . . . . . 50 in-lb*
Fuel tank bolts . . . . . . . . . . 10-13.5 ft-lb*
FRONT SUSPENSION / STEERING:
Fork bridge bolts - lower . . . . . 18 ft-lb
Fork bridge bolts - upper . . . . . 14.5 ft-lb
Fork cap air fitting (85-89) . . . . 5.7 ft-lb
Fork drain bolt . . . . . . . . . . 69 in-lb = 5.7 ft-lb
Fork slider Allen bolt . . . . . . . 14.5 ft-lb
Front axel pinch bolt . . . . . . . 9.5 ft-lb
Front axel nut . . . . . . . . . . . 43 ft-lb
Front brake disc bolts . . . . . . . 16.5 ft-lb
Front bevel geat case bolt . . . . . 8.5 ft-lb
Handlebar holder mounting Allen bolt 17.5 ft-lb
REAR SUSPENSION / FINAL DRIVE:
Brake torque rod bolt/nut . . . . . 22 ft-lb
Final drive - bearing case bolts . . 25 ft-lb
Final drive - drain plug . . . . . . 14.5 ft-lb
Final drive - mounting nuts . . . . 17.5 ft-lb
Rear axel nut. . . . . . . . . . . . 80 ft-lb
Shock absorber nuts . . . . . . . . 26 ft-lb
Steering stem bolt . . . . . . . . . 29 ft-lb
Swing arm retainer lock nut . . . . 9.6 ft-lb
Well I was close..
