Pulling to the right.. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 08-19-2009, 09:27 PM Thread Starter
ruk
Question Pulling to the right..
I have recently revived my baby, a 2001 VN750. It has been sitting outside on its kickstand since the summer of 2007. The last time I rode her, she wasnt doing too good. Throttle response was very slow and unresponsive. I was getting a coolant leak at the base of the cylinder. To make a long story short, I got her started after charging the yuasa batt and changed oil. After 10 cranks, she started! Rough at first and would only remain running with the choke, but, she eventually ran at 70%. My concern is that now she is pulling to the right. What could cause this? low inflated tires? Fork oil need replacment? Sticky fork maybe? Any help would be greatly appreciated.
PS although she sat outside for a while, I covered her up good.
Ruk,
2001 VN750-Black/Silver
9900 Miles
Stock Everything
=Rotella-T 10W-40, SuperTech 6607=
ruk is offline
post #2 of 16 (permalink) Old 08-19-2009, 10:47 PM
If it was sitting for 2 years outside I am surprised it even started...but I would guess your tires are the problem.
Check the air pressure and see if the tires are out of round.
post #3 of 16 (permalink) Old 08-19-2009, 11:46 PM
Glenn M's Avatar
Here are a few things that may be causing the problem. Tires, fork oil, rear shock air pressure uneven or the swing arm is out of alignment.
Glenn
1985 VN700
Saddle Bags
Small Sport Windshield
R/R moved
Home built coasters
Kaw touring front fender
1990 Fuel tank
Kenda Kruz 110/90-19 & 170/80-15 tires
NGK Iridium plugs
NGK plug caps and 7mm copper core wires.
Deer Whistles
My VN700 pic's
VROC #7740
Glenn M is offline
post #4 of 16 (permalink) Old 08-20-2009, 12:17 PM Thread Starter
ruk
Thanks for the reply. I am definitely suspecting the fork oil/seals. I will be checking the forks and tire pressure. I will update once I am done checking the bike.
Knifemaker: I was also surprised that it started. I remember putting half a can of seafoam in the tank before I left her alone. The real reason I stop riding is that after I changed oil and started the bike, the oil turns black after a few minutes. I dont think thats normal. I also smell gas in the oil. At first I thought it was the coolant leak from the base of the cylinder but now I'm stumped. I have no choice but to pull the engine and start looking inside.
Ruk,
9900 Miles
Stock Everything
ruk is offline
post #5 of 16 (permalink) Old 08-20-2009, 01:22 PM
spiral_72's Avatar
How about the right front caliper is stuck due to corrosion?
It'd be easy to check. Lift the front end and spin the tire.
No?
spiral_72 is offline
post #6 of 16 (permalink) Old 08-20-2009, 01:41 PM
No?
That would not cause it to pull to the right, there are bikes with only one disk for braking and they stop straight.
post #7 of 16 (permalink) Old 08-20-2009, 01:46 PM
This could be from carb flooding and allow too much fuel into the crankcase through the piston rings.
Welcome to the group, hope you get your ride going.
post #8 of 16 (permalink) Old 08-20-2009, 09:56 PM Thread Starter
ruk
Thanks all for such good suggestions! The bike is at my father in law's so I will not be able to work on it until Saturday. I will most definitely keep everyone updated.
i already checked the calipers/pads, they are in good shape and not rubbing each other.
the only thing I can think of at this point is probably the fork/oil and seals.
niterider: would that explain the black contaminated oil? I mean I literally just changed it and then after 5 minutes of the motor running , its black.
Ruk,
9900 Miles
Stock Everything
ruk is offline
post #9 of 16 (permalink) Old 08-20-2009, 10:36 PM
Glenn M's Avatar
I give up!!!
Glenn
1985 VN700
Saddle Bags
R/R moved
Home built coasters
1990 Fuel tank
NGK Iridium plugs
Deer Whistles
My VN700 pic's
VROC #7740
Glenn M is offline
post #10 of 16 (permalink) Old 08-21-2009, 02:01 AM
You may need an engine flush to clean out the crank case.
My engine oil is not really ever clean. I have trouble seeing the level through the glass window. I think my engine runs rich, the pipes are rather black and sooty looking. But I am not messing with it, it runs good, and getting 46 mpg.
