Neat trick - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 07-20-2009, 01:19 PM Thread Starter
spiral_72's Avatar
Neat trick
A little trick I'd like to share:
I pulled the rear suspension off my 92 VN750 yesterday. One of the shock bushings was rusted on the mounting stud. No amount of tapping and WD-40 would loosen it. I got the shock off, but the bushing was stuck.
To make a story short, the rubber of the bushing got fragged. Wouldn't you know a 1" length of 3/8" (I think) heater hose works perfectly as a replacement! So perfect in fact, that I wonder if that's OEM!?
I rode it this morning 32miles to work and noticed no problems.
spiral_72 is offline
post #2 of 2 (permalink) Old 07-20-2009, 02:29 PM
Calif Rider
weh44att's Avatar
Good info spiral, for maybe temperary fix. It may not be as hard a rubber as original. Keep a good eye on it, that it does not smash and split and let the bolt wobble.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
