Bigger IS Better! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 07-07-2009, 09:11 PM Thread Starter
ExNewbie..Still Learnin'!
rsawyer's Avatar
Bigger IS Better!
Recently oversized my tires to Metzler 880 Marathons with the 110-90/19 in the front and the 170/80-15 in the back. What a difference!
Didn't think it would do much but cracks/tar ribbon repairs/grooves on the pavement, no longer an issue. Still brace for what's coming but ends up being very smooth.
Also noticed the true speed vs speedometer change which was surprising but welcomed. Like the new "beefier" look as well.
Had the shop mount/balance but changed them out myself (including spline/speedometer lube, of course) which takes a little patience, but well worth the effort. Toughest part is meshing the rear tire assembly with the final drive gears. No real trick other than patience, swearing, and more patience.
Anyway, thought I'd post the results in case anyone others were considering oversizing the next time they change treads.
'89 Vulcan 750
VROC# 30232
HID Headlamp Conversion
V&H Cruzers (great sound)
Kaw V-Force Windshield
Kaw Rear Luggage Rack
Kaw Engine Guard
VN750.COM Grill Cover
W&M Black Magic Saddlebags
Diehard M/F Battery
R/R Replaced/Relocated
Stator Replaced
Voltmeter Installed
Splines Lubed
Front - 110/90-19
Rear - 170/80-15
Carbs Balanced
Carb Mix Adjusted
Fuel Tank Derusted/Lined/Sealed
NGK Iridium Plugs
rsawyer is offline
post #2 of 10 (permalink) Old 07-07-2009, 09:33 PM
I oversized the front and rear with the same 880's last Thursday. Went for a 360 mile ride this past weekend to break them in. Very happy with the new sneakers for all the reasons mentioned above.
Glenn Douglas
Londonderry, NH
GDouglas is offline
post #3 of 10 (permalink) Old 07-07-2009, 11:32 PM
I didn't go with the ME's but I did go oversize with Dunlop 404's and I have to say it is a much better handling bike and I stayed with the same brand,so at this point I'll have to attribute it to more rubber on the road.I agree in this case Bigger is better.
post #4 of 10 (permalink) Old 07-08-2009, 01:42 AM
cglennon's Avatar
I'm not ready for tires just yet, but Metzlers are on the short list. Would you mind posting a few pictures of your new setup when you have a chance?
Chris Glennon - Portland, OR
cglennon is offline
post #5 of 10 (permalink) Old 07-09-2009, 03:11 PM Thread Starter
rsawyer's Avatar
Will do. Will try to get them uploaded over the weekend.
'89 Vulcan 750
VROC# 30232
Kaw Engine Guard
Diehard M/F Battery
Stator Replaced
Voltmeter Installed
Splines Lubed
Front - 110/90-19
Rear - 170/80-15
Carbs Balanced
Carb Mix Adjusted
NGK Iridium Plugs
rsawyer is offline
post #6 of 10 (permalink) Old 07-09-2009, 09:23 PM
Here are a couple pics othe Metzlers (110-90/19 and 170/80-15) I put on last week. The first pic is of the stock size Dunlop 404.
ID:	2031   Click image for larger version
ID:	2032   Click image for larger version
ID:	2033   Click image for larger version
Glenn Douglas
Londonderry, NH
GDouglas is offline
post #7 of 10 (permalink) Old 07-09-2009, 11:10 PM
here is a picture of the Dunlop 404 170 on the rear of my bike
post #8 of 10 (permalink) Old 07-10-2009, 04:15 PM
Concert connoisseur
wib714's Avatar
I put a new rear 404 on my bike but just aired up the front one for a week or two till I can buy a new front, just air alone in the front made a big difference on the road cracks and uneven pavement. so no matter what you got, keep an eye on that tire pressure!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #9 of 10 (permalink) Old 07-12-2009, 12:34 PM
Expert Advice Giver
mgough983's Avatar
Big Tars
Bigger is Better......I put the Avon Venoms on front and rear and it is like the bike is glued to curves that I used to take a lot slower. It also helped the stability when running over the patches and cracks in the road.
1994 VN750
32K+
Vance & Hines Cruzers
Avon Venom Front & Rear Tire
Mustang Seat
Fire and Steel Luggage Rack
Fire and Steel Engine Guard
Fire and Steel Sissy Bar
KawaVulcan Saddlebags
eBay Genuine Imitation Chrome Mirrors
Kury Chrome Levers
Battery Tendered
Taillight LED'd
Splines Lubed
Wheelies Popped
2009 Triumph Rocket III
1974 Suzuki TS250
mgough983 is offline
post #10 of 10 (permalink) Old 07-13-2009, 12:08 AM
cglennon's Avatar
Thanks for the pictuures!
cglennon is offline
