Front brake operation question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 15 (permalink) Old 07-06-2009, 09:05 AM Thread Starter
750Doug's Avatar
Do you guys know (or gals) what in the brake system is supposed to or does, cause them to release after you let go of the lever?
Is it the fluid returning to a "relaxed" state, or a spring in the MC?
I ask because mine is starting to intermittently not release when I let go of the lever; I have to push the lever forward so the bike will roll. Used to be they would stick when used the first time coming out of the garage after a few days of no use, but yesterday they stuck twice after, and while I was out riding for a while.
I changed the brake fluid twice last year, now its less than a year old, and I used synthetic at the time. It doesn't look new anymore, but it doesn't look all that bad just yet either. I'm going to flush and change it this week anyway just to rule it.
Seems like an odd problem, and made me start wondering what it is that is supposed to make them release...
TIA.
750Doug is offline
post #2 of 15 (permalink) Old 07-06-2009, 09:16 AM
dragonrider's Avatar
doug , there is a spring on the piston in the mastercylinder on the piston, yours might be weak or it might be dirty , you might need a rebuild.
DRAGONRIDER
RIDE LONG AND RIDE SAFE
dragonrider is offline
post #3 of 15 (permalink) Old 07-06-2009, 09:59 AM
On my maxim I had problem with the calipers. I removed them and cleaned them up. Fixed the problem.
post #4 of 15 (permalink) Old 07-06-2009, 12:12 PM
1986vn750's Avatar
What color is your fluid, my piston at the wheel was sticking and i had fluid with water in it. I took the master cylinder apart, and cleaned everything, then bleed the system.
1986 Vn750
18,800 miles, and counting
Bone Stock
New cam chain tentioners
all fluids changed
Spline Lube
windshield
Engine Guard
B-stone S11 RWL-stock sizes
*wanted*
New grips
2001 Vn750
13,100 miles, and counting
spline lube
Bridgestone S11 100/90
Shinko 170/80
rear end oil change
aftermarket mirrors
windshield
otherwise all stock
*anticipated mods*
Engine Guard
1986vn750 is offline
post #5 of 15 (permalink) Old 07-06-2009, 12:20 PM
Vintage bike addict
antiq's Avatar
IIRC there is a very small passage in the MC that allows some of the fluid to return. That passage may be partly blocked. A MC rebuild or at least thorough cleaning may be needed here.
Eleanor Roosevelt.
antiq is offline
post #6 of 15 (permalink) Old 07-06-2009, 05:47 PM
1986vn750's Avatar
for sure, i had this "jelly" like substance in mine, and it plugged up my small hole in the master cyclinder. My handle was very firm, i flushed it out, and blead it, now its perfect
1986 Vn750
Bone Stock
all fluids changed
Spline Lube
windshield
Engine Guard
*wanted*
New grips
2001 Vn750
spline lube
Shinko 170/80
rear end oil change
aftermarket mirrors
windshield
otherwise all stock
*anticipated mods*
Engine Guard
post #7 of 15 (permalink) Old 07-06-2009, 07:33 PM
93VN750's Avatar
Be a great time to flush out all the old fluid and start fresh from an unopened can.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #8 of 15 (permalink) Old 07-06-2009, 09:24 PM
CWO3 Navy (Retired)
cliffhusn's Avatar
I have the T-shirt so to speak, rebuild the M/C and make certain that you use compressed air on the MC Chambers to clean out the return hole. That will cause you to lock up if it's not open.
The Flag on my bike honors those who serve our Country and those who have served!
cliffhusn is offline
post #9 of 15 (permalink) Old 07-06-2009, 09:45 PM Thread Starter
750Doug's Avatar
Thanks for taking the time guys. I'll start going thru it then and see what's what. I'm thinking since it's so intermittent that it's probably dirt or grime somewhere in there. I don't know why but I was thinking the MC was rebuildable/fixable. Probably the long holiday weekend and trying to get ready for work or something...anyway, thanks for the replies, and I'll get back with the findings.
750Doug is offline
post #10 of 15 (permalink) Old 07-06-2009, 09:59 PM
CWO3 Navy (Retired)
cliffhusn's Avatar
The MC is rebuildable, you can buy a kit on ebay for about $29.00. I've rebuilt 2 of them so far. In the MC there is a larger hole and right next to an extremely tiny hole smaller than a pin head; that hole MUST be open and clean or you will lock up! Use compressed air to clean out the chambers, you'll feel air coming out of it when you do so you'll know it's clean. Good time to flush out your system and replace the fluid. Buy yourself a set of speedbleeders if you don't have them, it makes bleeding the brakes a breeze.
