ABS Equivilent - Traction Control Brakes - anyone tried it? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 15 (permalink) Old 07-02-2009, 05:57 PM Thread Starter
PoggiPj's Avatar
Send a message via AIM to PoggiPj
Question ABS Equivilent - Traction Control Brakes - anyone tried it?
I have read about this $80 device, Traction Control Brakes (TCB) that is supposed to emulate Anti-Lock Braking (ABS). The small device replaces the Banjo Bolt that attaches your brake line to the Master Cylinder or the Brake Calipers (can install it at either end).
Their URL is http://www.tractioncontrolsystems.com
Has anyone installed one of these on their Vulcan? If so, I'd be interested in your feedback. I'm considering this for my Vulcan and my Honda VTX1300.
Regards,
Pete in Gaithersburg, MD
1996, 6,000 miles
Relocated R/R, Corbin seat, Plexifairing III, Sunpro Voltmeter, Sears MF.
Xelement X840 Saddlebags
PoggiPj is offline
post #2 of 15 (permalink) Old 07-06-2009, 09:48 PM Thread Starter
PoggiPj's Avatar
Bump - I guess no one here has ever tried this gizmo?
Regards,
1996, 6,000 miles
PoggiPj is offline
post #3 of 15 (permalink) Old 07-06-2009, 10:52 PM
Never tried it. Sounds interesting.
Harvey_birdman is offline
post #4 of 15 (permalink) Old 07-07-2009, 08:55 AM
first time i ever heard of something like that...pretty neat
dutter is offline
post #5 of 15 (permalink) Old 07-07-2009, 09:18 AM
cglennon's Avatar
I have something similar attached to the front brake of my road bike (the pedal kind). Basically, it is a spring, mounted inline on the brake cable that acts like a little shock absorber. Grab the brake fast and hard and the spring expands preventing wheel lockup.
This device looks similar.
They take a little bit of getting use to (at least on a pedal bike), much like going from an automobile standard brake system to power assist. There is a little bit of float when you first hit the brakes with power assist that does not exist with the standard system.
Chris Glennon - Portland, OR
cglennon is offline
post #6 of 15 (permalink) Old 07-07-2009, 12:12 PM
flitecontrol's Avatar
I'd like to see some user reviews, and I couldn't find any.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #7 of 15 (permalink) Old 07-07-2009, 03:24 PM
VN750_DawgsFan's Avatar
I'd be interested to read some reviews on this myself. Looks Interesting.
My daily ride
Metzler ME880s
NGK caps, wires and Iridiums
Coasters (made by Lance328), earshave and rejet with screws turned out 3 turns
Volt gauge w/ custom mounting cup by Lance328 wired into headlight bucket 13.5v-14v
National Cycles Plexistar 2 windshield
DEKA battery
Mutazu GA Black hard bags w/ custom support brackets and relocation brackets made by Lance328
Custom lowers made by Lance328
Vance&Hines Cruzer exhaust pipes
H.I.D. Conversion kit
VN750_DawgsFan is offline
post #8 of 15 (permalink) Old 07-07-2009, 04:44 PM
Never heard of it before either, but I would like to see some reviews.
post #9 of 15 (permalink) Old 07-07-2009, 09:20 PM
Ba dum dum, ching...
Ron_G's Avatar
OK, I'm trying to understand the physics at play here. I understand how this would work on the front brake but it's when the rear brake gets locked up that the trouble starts. The rear brake locks up and starts to go sideways. You release the rear brake and the bike highsides. Since our rear brake is not hydraulic I don't think this will solve the problem for us.
Of course it's been 25 years since I sat in a physics class so I'm open to correction here.
R
Yes, it's my mid-life crisis.
Sweet Jane...
http://images5a.snapfish.com/232323232%7Ffp63386%3Enu%3D457%3A%3E6%3C3%3E258%3E  WSNRCG%3D3345343785349nu0mrj
Ron_G is offline
post #10 of 15 (permalink) Old 07-07-2009, 09:39 PM
http://www.tcbbrakesystems.com/tcb-testimonials.html
(keep in mind these are provided by the maker of the device...)
I have to say that from what I read, there seems to be very little difference in what this thing says it does and just letting a bit of air in your braking system.
They even say there is no guarentee that your wheel will not lock, just that it would be harder for you to do...again much like adding a bit of air to your break line.
This seems to me to be a good device for those too lazy to take the time to learn how to use their brakes properly. You are in fact making your brakes "weaker", so I worry when you really need to stop your bike ...NOW... , that you will be unable to.
Seems most of the "testimonials" were from older riders on what looked like huge bikes , and unknown years of experiance riding.
I also noted there were no testimonials of using these brakes in wet condtions, and of course no background testing to show that the rider could have stopped in a shorter distance without the system installed. Some times a foot or two can make alot of difference.
I have seen alot of data on real ABS systems and would be the first to reccomend them if you have that option. This "total control" system looks to me like a poor mans replacement, much in the same vein as tinting your headlight bulb blue so its "just like those high end HID lights" (when in fact you are actualy decreasing the amount of light produced)
Take the time to learn how your brakes work and practice panic stops in a safe area on a regular basis.
