Axle diameter - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 06-17-2009, 06:41 PM Thread Starter
Axle diameter
does any one know the rear axle diameter of a vn750, so I don't have to pull mine out and measure it?
post #2 of 9 (permalink) Old 06-17-2009, 07:50 PM
Calif Rider
weh44att's Avatar
Are you asking the diameter of the bolt that goes through the wheel. If so you can take just the nut off and measure the bolt end.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #3 of 9 (permalink) Old 06-17-2009, 09:00 PM Thread Starter
I know can do that but I was needing a pretty accurate measurement of the unthreaded part for some machine work.
post #4 of 9 (permalink) Old 06-17-2009, 09:55 PM
flitecontrol's Avatar
The diameter isn't listed in either of my manuals. Sorry.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #5 of 9 (permalink) Old 06-17-2009, 10:49 PM Thread Starter
! guess I need to get out the calipers then.I couldn't find it in the factory manual or Haynes ,I was hoping one of you guys with a Clymers could tell me
post #6 of 9 (permalink) Old 06-17-2009, 11:57 PM
You may want to run it out a little bit and measure the smooth end.
post #7 of 9 (permalink) Old 06-18-2009, 01:20 AM
I think I read a post with a link, or saw a drawing in the gallery of some lowering plates for the rear axle with dimensions for the hole. Sorry but I don`t recall who posted it, and my search skills are not very good either.
post #8 of 9 (permalink) Old 06-18-2009, 09:13 PM
Hi,
I just replaced the rear axle nut and the measurements of it were M16 x 1.50 fine thread pitch.
So the axle is M16 (don't know if that's accurate enough for your machine work).
Cheers, Trace.
Trace is offline
post #9 of 9 (permalink) Old 06-18-2009, 10:17 PM Thread Starter
Originally Posted by Trace View Post
Hi,
Cheers, Trace.
Thanks trace tat means it is a 16mm bolt and that tells me what I need to know, after doing a little web math (Cheating) that works out to .630 which falls between 5/8 and 11/16",Denny
