Back wheel quick question? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 05-18-2009, 01:23 PM Thread Starter
Hi,
Is there any problems swapping the bikes original back wheel with a replacement one from another vn750.
I can't see any but thought I'd ask incase there's something I've overlooked.
Thinking of getting a spare to polish and paint and see if I like the difference while still being able to use the bike.
Cheers, Trace.
Trace is offline
post #2 of 8 (permalink) Old 05-18-2009, 01:37 PM
93VN750's Avatar
Other than the color, should all be the same.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #3 of 8 (permalink) Old 05-18-2009, 01:37 PM
fergy's Avatar
Shouldn't be a problem. Go for it!
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #4 of 8 (permalink) Old 05-18-2009, 02:48 PM Thread Starter
Thanks, just got one 2 mins. ago on best offer from ebay for 47 ($71) that's including postage!
Cheers, Trace.
Trace is offline
post #5 of 8 (permalink) Old 05-18-2009, 02:51 PM
Newb with a Bullet!
krebsne's Avatar
I swapped one out when I was super noob. It was really easy. Thinking about painting the old one and putting a new tire on it and swapping them back. Will make a thread about it if I do.
krebsne is offline
post #6 of 8 (permalink) Old 05-18-2009, 04:18 PM Thread Starter
Hi Krebsne,
I think I put the question across badly, I wasn't asking about the difficulty of removing and replacing the wheel (which I have done many times) I meant if there were any technical issues with the final drive and using a wheel that maybe a lot different in age.
Thanks for replying anyway.
Cheers, Trace.
Trace is offline
post #7 of 8 (permalink) Old 05-18-2009, 04:53 PM
Newb with a Bullet!
krebsne's Avatar
I didn't have any problems. I think they are all the same. I bet if they didn't work you'd know because they wouldn't go together. I mean you'd have to have a dimension issue or something, right? Something in the new wheel bigger or smaller than the counterpart in the old wheel.
Most the used wheels I see on eBay and such don't even mention the year, so I figure it's irrelevant.
krebsne is offline
post #8 of 8 (permalink) Old 05-18-2009, 05:40 PM Thread Starter
I'll soon find out
Turns out the wheel is from the same year anyway.
Cheers, Trace.
Trace is offline
