Fork Shuddering? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 05-11-2009, 02:31 AM Thread Starter
VulcRider24's Avatar
Fork Shuddering?
Going down the highway on my recently purchased '94 Vulc I went to pass someone and was doing about 75-80 MPH and I started feeling this slow vibration coming up through the handlebars that got more intense as speed increased. I looked down at the front wheel and saw the whole assembly shuddering back and forth rapidly. once I slowed to about 65-70 the shuddering was much less pronounced.
I'm not sure if the Vulc is trying to tell me that I shouldn't be going that fast or if I have a serious problem that I need to have looked at.
Has anyone else experienced this?
I would like to emphasize that I'm not a reckless rider, I was only going that fast to get past a car that was driving erratically and I felt was a threat.
VulcRider24 is offline
post #2 of 11 (permalink) Old 05-11-2009, 02:42 AM
The Professor
lance328's Avatar
Was the wheel shuddering back and forth or the fork assembly?
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 11 (permalink) Old 05-11-2009, 02:44 AM Thread Starter
The fork assembly was. It wasn't shuddering where the forks are connected to the frame, just down where the wheel and brake assembly are.
post #4 of 11 (permalink) Old 05-11-2009, 02:48 AM
The Professor
lance328's Avatar
You may have an out of round tire, or it may just need to be balanced.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #5 of 11 (permalink) Old 05-11-2009, 02:59 AM Thread Starter
Thats what I was thinking, is it as dangerous as it feels?
post #6 of 11 (permalink) Old 05-11-2009, 03:03 AM
The Professor
lance328's Avatar
It may not be dangerious but I would get it fixed ASAP.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #7 of 11 (permalink) Old 05-11-2009, 10:57 AM
dirtrack650's Avatar
Check and tighten every nut and bolt on your front end. My bro put his vintage gold wing in the ditch totaling it because the triple clamp bolts were loose. After that incident, I check and tighten every season.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #8 of 11 (permalink) Old 05-11-2009, 01:00 PM Thread Starter
Took her to a Kawasaki dealer and they told me both my tires were low! 12 in the front and 10 in the rear! I got a scolding from the mechanic and really learned my lesson. The tires "looked" fine so I didn't bother checking the pressure. I'm definitely checking that more often. I took it on the highway and the shuddering was much less noticeable but I looked down and could still see the forks shuddering a little bit but that was at a much higher speed.
Thanks for the help guys
post #9 of 11 (permalink) Old 05-11-2009, 02:16 PM
Check the balance on the front tire.
post #10 of 11 (permalink) Old 05-11-2009, 08:41 PM
750Doug's Avatar
Buy an air gauge, and check the tire pressure often. (Look them over often as well for damage.) I have several/many gauges, if you can't swing one, let me know and we'll call it and early x-mas gift...
750Doug is offline
Tags
forks , shuddering
