fork oil change? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 05-02-2009, 01:50 PM Thread Starter
D2u
D2u
D2u's Avatar
fork oil change?
How the h**l do you compress the fork springs. I have 285lbs leaning on them and i can't get them to compress enough to get the retainer ring out.
1992 VN750 22,350 miles 18,700 when I bought it last year 04/17/2008
Streetshield EX
degoat
drilled mufflers
Capped (soon to be coaster)
Custom Grips
Wide blade levers
Throw over leather saddlebags
Deka MF AGM ETX15L
NGK Iridums
DIY Brackets,and highway pegs
To do list.
custom seat
teardrop mirrors
DIY Floor boards
D2u is offline
post #2 of 9 (permalink) Old 05-02-2009, 03:11 PM
The Professor
lance328's Avatar
Did you drain the fluid?
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 9 (permalink) Old 05-02-2009, 05:14 PM Thread Starter
D2u
D2u
D2u's Avatar
No I didnt cause that is like step 10 in clymers.step 2 was compress spring and remove retaining clip.I thought of doing that,but then i figured i still wouldnt be able to compress the spring,and all i would have done was drained the oil and not been able to put new oil back in.
Streetshield EX
degoat
drilled mufflers
Custom Grips
Wide blade levers
Deka MF AGM ETX15L
NGK Iridums
To do list.
custom seat
teardrop mirrors
DIY Floor boards
D2u is offline
post #4 of 9 (permalink) Old 05-02-2009, 06:55 PM
The Professor
lance328's Avatar
Read through this thread, it will help.
https://www.vn750.com/forum/showthread.php?t=10544
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #5 of 9 (permalink) Old 05-02-2009, 08:15 PM
Addicted to Projects
bullwinkle's Avatar
Which thread Lance??
Charlie
VN700 project bike 98% completed!!
68 Bushwhacker this winters project (in the works)
86 Honda GL1200i (winter project #2)
82 kz440 daily rider for now!
A few clowns short of a circus now aren't we?
bullwinkle is offline
post #6 of 9 (permalink) Old 05-02-2009, 09:32 PM Thread Starter
D2u
D2u
D2u's Avatar
Once again Lance you have pulled me from the flames! Your tip was right on the money.I drained the oil and it went much better.Man that oil in the forks was nasty.I changed the rear shock oil as well.I can't belive the difference in the ride,and handling.
Streetshield EX
degoat
drilled mufflers
Custom Grips
Wide blade levers
Deka MF AGM ETX15L
NGK Iridums
To do list.
custom seat
teardrop mirrors
DIY Floor boards
D2u is offline
post #7 of 9 (permalink) Old 05-02-2009, 09:47 PM
750Doug's Avatar
I did my shocks a week after the forks and if I had known how much better they (forks & shocks) were going to feel, I'd have done it all last year.
Not a hard job, and the results are impressive.
750Doug is offline
post #8 of 9 (permalink) Old 05-05-2009, 07:04 PM
Undercover Sportbiker
AJCruzin's Avatar
I tried pulling the retainer on a set of 250 forks the other day and couldn't get it. Of course, they're not on the bike either, which makes it 1,000 times harder than it had to be...
AJCruzin is offline
post #9 of 9 (permalink) Old 05-05-2009, 08:49 PM
750Doug's Avatar
So how does this story end? Or has it not yet?
750Doug is offline
