HELP! Bottom Allen Bolt Won't Tighten - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 04-28-2009, 11:49 AM Thread Starter
Question HELP! Bottom Allen Bolt Won't Tighten
Fellow Vulcaneers --
The oil seals, dust seals and snap rings finally came in today and I was able to finish the job. I replaced the seals, filled with fresh 15w oil and reinstalled the forks on the bike; however, I've got a PROBLEM!
The bottom allen bolt will not tighten because the inside part is spinning freely. I did add a drop of blue loctite to the allen bolt. I thought by waiting to torque the bolt until everything was reassembled with tension on the inner spring I wouldn't have this problem!?!!!
I read about inserting a small diameter wooden broom handle (tapered at one) all the way down to the bottom of the fork to keep the inside part from turning. At this point is this my best solution? The broom handle will probably disperse some oil. To get an accurate oil level I will probably need to drain all the oil and then add fresh oil.
Does anyone have any other ideas?
Thanx in advance!
FlaRider is offline
post #2 of 9 (permalink) Old 04-28-2009, 03:12 PM
fergy's Avatar
Just bumping this to get you some help! Never done a fork oil job yet. good luck
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #3 of 9 (permalink) Old 04-28-2009, 03:19 PM Thread Starter
Fegry --
I wish this had gone as well as the spline lube! If I have to go in there a second time I will definitely take pics and do a write-up.
Lance gave me a couple of ideas over the phone. I hope one of them works!
Thanx for your response!
FlaRider is offline
post #4 of 9 (permalink) Old 04-28-2009, 03:35 PM
You could try bumping the screw with a 3/8 drive impact. It may turn it fast enough that the rod inside will not turn with it. Then check the torque on it. Be careful not to strip it.
post #5 of 9 (permalink) Old 04-28-2009, 04:24 PM
93VN750's Avatar
That's what I did, worked like a champ.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #6 of 9 (permalink) Old 04-28-2009, 11:43 PM Thread Starter
Thumbs up Lance is da Man!!
UPDATE:
I want to give Lance a public kudo! This man rocks!
He has in-depth knowledge of all the moto systems and thinks out of the box!
Just as important, he goes the extra mile to share his knowledge and help!!!!
I followed his suggestions given via telephone to tighten the bottom allen bolt: (He's helped me overcome a crisis via telephone on several other occasions!)
* compress the forks with tie-down straps
* use heat to disolve the loctite applied the previous night
* use an allen socket on my rachet to quickly turn the bolt
* final tighten with torque wrench
IT WORKED!!!
Even though I spent a few well-invested $ on tools, heat gun, etc. it's still MUCH cheaper than 2 or 3 hours labor at Ma Kawi's $80/hour rate!!!
My Thanx to Lance and each of you who responded!!
Thanx in advance!
FlaRider is offline
post #7 of 9 (permalink) Old 04-28-2009, 11:45 PM Thread Starter
Jon
NiteRider and Jon --
Good idea! I will file it away for future use.
Many thanx!
FlaRider is offline
post #8 of 9 (permalink) Old 04-29-2009, 11:48 PM
The Professor
lance328's Avatar
Thanks for the Kudos, just glad I could help.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #9 of 9 (permalink) Old 04-30-2009, 03:48 PM
Thumbs up
I will second that I had a strange problem with my oil light coming up
One Call - Thats ALL - to Lance - He is meticulous
Lance rocks!
UPDATE:
IT WORKED!!!
Not a Virgin but has a Halo
RogerGA is offline
