A Couple Of Fork Questions - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 04-25-2009, 01:13 AM Thread Starter
On His Lady Vulcan
wkrizan's Avatar
A Couple Of Forking Questions
OK after searching the site for 30+ minutes I gave up, so forgive me if theres already a post concerning these questions that I am about to ask.
1. What is the outside diameter measurement of our stock forks tubes?
2. What is the stock length of our forks tubes?
I am asking these questions in prepping and researching to do some more mods.
As I am sure a few of you have already guessed, I am looking into replacing my fork tubes with longer ones. I want to give it a bit more rake without having to mess with the trees or neck and tubes are cheap. So feel free to hit me with some answers people, thanks.
Peace
Pictures of the "Ladies"
wkrizan is offline
post #2 of 4 (permalink) Old 04-25-2009, 04:25 AM
The Professor
lance328's Avatar
Peace
Tube diameter = 38.0 mm
Tube and slider extended lenght = 850.0 mm From top of tube to center of axle.
!!!!WARNING!!! Extending your fork lenght will NOT change your "steering head" rake angle, it will remain the same. It will however raise the bikes center of gravity and change the steering geometry which WILL deminish the handeling charastics. MOST IMPORTANTLY it will move the oil to the back of the engine away from the oil pickup, and WILL greatly improve your chances on a lubrication failure.
Our engines have a "WET SUMP" design and need to remain on a horizontal plane for propper lubrication. Some engines are a "DRY SUMP" design and can be mounted at ANY angle with NO ill effects.
I advise againt this modification but it will be your choice.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 4 (permalink) Old 04-25-2009, 09:07 PM
This wet sump design, requiring the vn750 engine to be mounted so as to keep the oilpan level, raises a question for me. How steep an incline can we climb before this becomes a lubrication problem? Or will the laws of physics dump my ^$$ off the back of the bike, before oil pickup ceases?
https://www.vn750.com/forum/11-vn750-general-discussion/9127-top-ten-items-you-would.html
post #4 of 4 (permalink) Old 04-25-2009, 09:15 PM
Jace Bror's Avatar
well if you have the stock seat, it would have to be a pretty steep incline to dump you since we have a backrest
Jace Bror is offline
