Clicking Sound from Rear Brake Hub - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 04-13-2009, 11:27 PM Thread Starter
Ride Long and Prosper!
FlaRider's Avatar
Question Clicking Sound from Rear Brake Hub
Howdy Vulcanians --
There is a slight clicking noise coming from inside the rear brake hub. The first time I noticed it was when I first got the bike a few months ago and I was adjusting the rear brake pedal freeplay. With the bike on the center stand each time I would spin the wheel I noticed a very slight clicking sound almost like something small was loose and tumbling inside the hub. I forgot about it because there was no ill effect.
Today after completing the spine lube I noticed the same sound as I was spinning the rear wheel to make sure the brakes worked and everything was okay. The wheel spins freely and the brakes seem to be working properly.
As part of the spline lube I inspected the rear brakes and everything seemed okay. I did not notice any loose parts. The brakes and drum have very little wear but a LOT of brake dust. I carefully cleaned the drums and pads with brake cleaner. The brakes seem to work much better after clearning. They grab the rear wheel quicker and with less pedal pressure than before.
I'll do a slow and careful test ride tomorrow and see if I can detect anything amiss.
Anyone have any idea what the sound might be? Do I need to remove the rear wheel again!!!??? Uhuug
Thanx in advance!
OldFlaRider
USAF (Retired)
"Mr. Spock" 2006 VN750 370 miles (7/21/09)
Kawi Bag Supports
Relocated Signals/Locks
Saddle Bags
Relocated RR w/Lance Bracket
Corbin Seat & ProTac Backrest
Memphis Shades Shield
Stebel Air Horn
K&N Air Filters
Iridium Plugs
Deka MF Battery
FlaRider is offline
post #2 of 4 (permalink) Old 04-14-2009, 12:23 AM
The Professor
lance328's Avatar
Originally Posted by FlaRider View Post
Howdy Vulcanians --
Thanx in advance!
Just tighten your chain! LOL
You may have a piece of debris behind the wheel coupling.
Remove wheel then remove the coupling retaining ring, coupling and damper.
Check the wheel bearings, might be time to replace.
FIRST!! Check your final drive oil level, Have you changed it?
Do you hear it more on the left or right?
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 4 (permalink) Old 04-14-2009, 11:38 AM Thread Starter
FlaRider's Avatar
Thanx for your reply Lance!
Yes, I changed the final drive oil. The sound is definitely coming from the right (brake hub) side. When I had the wheel off I checked the bearings by turning them by hand and they seem to turn smoothly. Is there any other way to check the bearings?
I studied the wheel assembly in the Clymers. I agree, I think the sound is most likely coming from a piece of debris behind the wheel coupling. The sound occurs each time as the debris falls from top to bottom only once per revolution. Very definitely something is tumbling inside behind the wheel coupling.
This sound has been there since I got the bike a few months ago. I've put several hundred miles on it without any problems. I'm tempted to do a test ride to check for problems before I remove the rear wheel again.
What do you think?
OldFlaRider
USAF (Retired)
Kawi Bag Supports
Saddle Bags
Stebel Air Horn
K&N Air Filters
Iridium Plugs
Deka MF Battery
FlaRider is offline
post #4 of 4 (permalink) Old 04-15-2009, 04:53 PM Thread Starter
FlaRider's Avatar
Lance and Vulcanites --
I removed and inspected the rear wheel. It only tool me about 2 hours this time vs. 5 the first time. It definitely gets easier when you know what you're doing! Thanx again, Fergy!
Following Lance's suggestion and using the Clymers as a guide I removed the coupling retaining ring, coupler, and rubber damper (see pic attached). I did not find any debris or any cause for the tumbling sound coming from the hub. Everything looked fine and the sound is not as loud now, barely audible. This evening I will do a slow careful test ride but I don't expect any problems. This sound has been there since I got the bike several months ago.
I can't believe this rookie took the wheel completely apart . . .well almost.
Thanx Lance!!!!!
Name:	Spline coupling dampner (2176 x 1632).jpg
OldFlaRider
USAF (Retired)
Kawi Bag Supports
Saddle Bags
Stebel Air Horn
K&N Air Filters
Iridium Plugs
Deka MF Battery
FlaRider is offline
