Tires to purchase suggestions ?? - Page 3 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 9Likes
post #21 of 29 (permalink) Old 02-10-2020, 11:44 AM
Retired USAF (IYAAYAS)
Chris and Shim's Avatar
I did find this: https://www.tacomaworld.com/tirecalc...0-80r15-150-90
Type in the correct current size and switch the view to "overlay" and it'll make more sense. The difference seems to more in width than height.
The rest of the chart doesn't really matter especially the speedometer changes.
Saddlebags, hard mounted
Fork mounted tool bag (now hard mounted)
Relocated rear turn signals
LED turn signals, brake lights and running lights
LED license plate frame
Engine Guard and Highway pegs
National Cycles Low Boy Heavy Duty windshield
Home made lowers (nice)
Custom seat (made by a local guy)
Iridium plugs (DPR7EIX-9)
Shenko 230 Tour Master tires at 11,123 miles
Splines lubed at 11,123 miles
Luggage rack
Light bar with LED lights
Progressive 412 shocks
Chris and Shim is offline
post #22 of 29 (permalink) Old 02-10-2020, 12:08 PM
Originally Posted by Chris and Shim View Post
I wish I could see a side-by-side comparison of the 170/80-15 next to the 150/90/15. If that's what you run Spockster then I know it'll fit mine as mine still has the factory tire-to-fender clearance.
I'm also curious about the difference in tire weights.
The main thrust behind making such a change for me is to get better freeway MPG/range.
There's some comparison pics in the thread I linked earlier, they're fuzzy now but you can see the height difference.. I see I haven't restored the pics I put in there.
If you search around the web, there may be some tire weights listed somewhere, I've used them for atv tires.
There would be some rpm drop with a taller tire, but I don't know if it's enough to give much change in mpg. Don't think anyone has made that comparison.
post #23 of 29 (permalink) Old 02-10-2020, 01:28 PM
Because of the minimal diameter change I think the MPG change probably wouldn't even be noticeable. I'll probably stick with the stock rear tire size then, but I do run the 110/90-19 on the front anyway.
I'm right on the edge of deciding to change mine out before I go down to the annual HCMR. I'm at 6K on this set and I think they are expected to see maybe 7K longevity. I'd hate for them to crap out so far away from home even though right now they seem to have lots of tread left. I'll put on much more than 1K between now and then.
This is a good thread for me also to think about different brands aside from Frank, the thread starter. Since the past two years have seen me getting in more miles per year than the previous years I might just opt for a longer lasting tire set.
Luggage rack
post #24 of 29 (permalink) Old 02-10-2020, 01:42 PM
Info I saw said that if you oversize one tire, you should oversize both, or there may be some adverse handling changes. Haven't tried that myself.
post #25 of 29 (permalink) Old 02-10-2020, 02:31 PM
I've not noticed any detrimental changes to handling (due to tires) at all since putting the current set of tires on (6K miles ago). The only time I did notice a handling change was solely due to the less-than-ideal positioning of my loadout at that time. Repositioning of the load cleared that up.
I'm not concerned about a 110/90-19 tire on the front and stock on the back. In fact I think it handles better with the larger front tire. It no longer reacts to tar snakes or ruts, or at the very least reacts FAR less with the 110 tire on the front.
As for the rear tire, since you, Spockster, said that you run the larger tires, have you noticed that it rides better?
Luggage rack
post #26 of 29 (permalink) Old 02-10-2020, 04:32 PM
Well if you want the best mileage, a skinnier tire would be better than a fat one do to rolling resistance. But then a taller one would lower your rpm at a constant speed. But then you’ll need more fuel to get there.
Keep in mind here we are talking 2-4 mpg differences at the most. So unless you’re traveling cross country you’re not going to save much $$ per mile.
I’d easily trade a few pennies for better traction and better braking you get from
a wider tire.
post #27 of 29 (permalink) Old 02-10-2020, 04:44 PM
Hard for me to say, I only rode about 3 miles before doing all the mods.
On tire width, keep in mind, the actual contact patch of the tread is approx. 3" or so at any given time, this is how we get chicken strips. The tire would have to be flat to be using the full width of the tread on any tire, except a Darkside tire.
post #28 of 29 (permalink) Old 02-11-2020, 10:37 AM
Not that much of a difference. I ran a 110 on the front and a 140 on the back before and handling was fine
Sent from my 100005206 using Tapatalk
OleDirtyDoc is online now
post #29 of 29 (permalink) Old 02-17-2020, 03:00 PM Thread Starter
Thanx for the heads up..I found a place in Quebec, thats reasonable.. and I can go and have them installed instead of mail order..
cheers!
Frank Loria is offline
