VN750 w/ ls650 shocks - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 7Likes
post #11 of 13 (permalink) Old 03-05-2020, 08:16 AM
What he said ^ (twice it seems)
The biggest issue with lowering the rear is cornering clearance and as mentioned the kick stand. Lowering the rear effectively increases rake, which is the same as extending the forks. In theory this would “slow” the steering, but no ones reported this as a problem. Decreasing the rake, or making the steering “quicker” could have bad results but I’ve not seen anyone do this on the Vulcan, which has slower steering than say a sport bike, so you’d have to raise the rear pretty far before bad things happen.
You can also lower the bike by moving the lower shock mounting point farther back, which allows you to keep the stock shocks. They used to make kits that did this, but most folks just use shorter shocks. (As the stock units suck anyway)
OleDirtyDoc likes this.
post #12 of 13 (permalink) Old 03-05-2020, 11:57 AM
Slide the forks up an inch in triple trees to bring the rake back. Only about an inch is needed. Also need to move the rectifier. Cornering clearance isn't that bad. It isn't gonna handle like a gsxr, but I still could ride aggressively. Must also remove the centerstand
Sent from my 100005206 using Tapatalk
post #13 of 13 (permalink) Old 03-05-2020, 12:03 PM
The lowering kit isn't hard to make either
