Front Brake Spongy - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
post #11 of 18 (permalink) Old 05-03-2019, 04:31 PM Thread Starter
Jason Pittenger's Avatar
Yes I did
Completed modifications:
Planned modifications:
Jason Pittenger is offline
post #12 of 18 (permalink) Old 05-06-2019, 05:11 AM
I have never had that procedure fail, on bikes or cars. As long as you don't let the fluid in the master cylinder get low, air cannot get into the system. Gravity will draw fluid through the system until there is no more air in the lines. It's possible you may have mechanical problems, like a leaking seal in the master cylinder.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #13 of 18 (permalink) Old 05-06-2019, 12:14 PM
calebj's Avatar
Originally Posted by Jason Pittenger View Post
I ran a pint through this morning. I didn't have any hoses to put on the bleeders, so I used a drip pan to collect the fluid. It made it worse! I have a coworker with a vacuum bleed system. I might give that a try.
Not having a hose to put on the bleeder valves is almost certainly the root of your issue.
GDI likes this.
1986 VN750 27k miles
1999 EN500 32k
1983 GL650i in pieces. Someday it will ride again.
calebj is offline
post #14 of 18 (permalink) Old 05-09-2019, 11:18 PM Thread Starter
When you're squeezing the front brake lever, and the cover is off, is it normal for the fluid to come squirting out the top? I don't fully understand how the master cylinder actually works.
A squeeze on the liver, causes fluid to come out one of the two small holes inside the chamber. If I squeeze it rapidly enough, the fluid squirts out into the air. Is that normal behavior? I don't get any leaks when the cover is on.
post #15 of 18 (permalink) Old 05-10-2019, 09:00 AM
It's normal, the cover should be in place when pumping.
post #16 of 18 (permalink) Old 05-12-2019, 11:18 AM Thread Starter
Plugged return port in the bottom of the master cyl. can do the same. With the cap removed, very carefully squeeze the lever and see if fluid squirts up out of the reservoir. Use rags so fluid doesn't end up on your paint.
So fluid squirting up and out of the chamber is not normal behavior? I'm confused.
post #17 of 18 (permalink) Old 05-12-2019, 12:14 PM
Yes, it's normal, see post #15.
post #18 of 18 (permalink) Old 06-11-2019, 07:53 PM Thread Starter
I thought I'd follow up with this, as I finally got it working!
I did the clamp on the brake lever overnight trick a few times. Every time, it'd be very firm in the morning.
But as I would ride, the lever would lose that firmness. At the end of the day, I could pull the lever back to the bar without locking the front.
How I finally fixed it was I put the clamp on the lever. I then sharply hit the calipers, hose, and the block behind the horn starting at the calipers and working my way up. I used a metal ruler to provide a sharp hit, but minimal weight so it would bounce back just as sharply. A 10mm wrench would also work for this. The theory being that any small air bubbles should be dislodged and head up the line.
It worked! It's not quite as firm as it was before I bled the brakes, but it's consistent over several days.
