Sqeaking/Chirping from front wheel - possibly speedometer wheel - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
  • 1 Post By Knifemaker
post #1 of 3 (permalink) Old 06-17-2018, 06:09 PM Thread Starter
Hello,
I am relatively new to wrenching on my bike, but brave none-the-less. Right now there is a chirping or squeaking noise coming from the front wheel. It speeds up and slows down in relation to the rotation of the wheel. I'm pretty confident that it's not the brakes and everything else there seems OK. So, I am beginning to suspect that it's coming from the wheel that drives the speedometer cable. So, I wanted to see if anyone has any recommendations for lubricating that. From what I remember of the old days in working on machines, I don't want to just shoot WD40 in there if it needs grease.
So, any suggestions would be greatly appreciated.
Thanks
Godbrain is offline
post #2 of 3 (permalink) Old 06-17-2018, 07:22 PM
Graphite lube for locks would probably be perfect. Could be the speedo gearbox at the wheel, if it's not the cable.
post #3 of 3 (permalink) Old 06-18-2018, 10:41 AM
Cable should be greased not oiled.
You can remove the cable from the wheel, (be careful as it can slide out of the cable housing) tie it up by the bars and go for a short ride. If it still squeaks, it's the gears in the hub, if not, the cable.
roadpouring likes this.
