Changing Front Tires - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 24 (permalink) Old 03-05-2009, 12:05 PM Thread Starter
Jace Bror's Avatar
I plan to remove my wheels on my own and change my tires. But I'm not sure the best way to hold up the front end. I still have my center stand. I know I should use a strap to hold the front forks to the center stand, so the stand doesn't fold. But what is the best way to hold up that front end?
Sold 750 (9-09)
Mustand Seat (6-09)
Balanced Carbs (4-09)
Adjusted Mix Screws (4-09)
R/R Relocated (3-09)
Splines Lubed (3-09)
Painted flat blak (3-09)
Kuri grips (8-08)
Kuri Longhorn pegs (8-08)
Iridium Plugs (8-08)
Highway bar/ engine guard(FS)
Facebook ID Eli Gaffke
Jace Bror is offline
post #2 of 24 (permalink) Old 03-05-2009, 12:17 PM
Lean the bike back and slide a block under the front part of the engine. Aslo you may try to strap the rear of the bike down by using some tihing heavy like a spare tire.
post #3 of 24 (permalink) Old 03-05-2009, 01:07 PM Thread Starter
Jace Bror's Avatar
And since I'm not really lifting the bike with the block just balancing it. It won't hurt the engine or my pipes?
Sold 750 (9-09)
Mustand Seat (6-09)
Kuri grips (8-08)
post #4 of 24 (permalink) Old 03-05-2009, 01:17 PM
That is right.
post #5 of 24 (permalink) Old 03-05-2009, 01:19 PM Thread Starter
Jace Bror's Avatar
I have to buy some straps to do that, but you think bungies would work instead
Sold 750 (9-09)
Mustand Seat (6-09)
Kuri grips (8-08)
post #6 of 24 (permalink) Old 03-05-2009, 01:29 PM
If using both methods at once, bungees aught to be okay.
When replacing the tire be sure that your spedo gear goes back into place right against the tire.
post #7 of 24 (permalink) Old 03-05-2009, 01:40 PM Thread Starter
Jace Bror's Avatar
?not sure i follow? i know about the speedo stuff, but does it have to go back together a certain way
Sold 750 (9-09)
Mustand Seat (6-09)
Kuri grips (8-08)
post #8 of 24 (permalink) Old 03-05-2009, 01:47 PM
It has a notch that it fits in. When I did the fork seals on mine I had not lined it up right. You will see, just examine it when you take it off. Also take a look at before removing.
post #9 of 24 (permalink) Old 03-05-2009, 01:51 PM Thread Starter
Jace Bror's Avatar
How tight does the speedo cable need to be when you put them back on. cuz i know that i tried to take it off before to spray some lube down it and it was really on there
Sold 750 (9-09)
Mustand Seat (6-09)
Kuri grips (8-08)
post #10 of 24 (permalink) Old 03-05-2009, 01:54 PM
I just take a small pair of pliers and apply a little bit of torqe on it.
