Clutch issue - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
 5Likes
post #1 of 11 (permalink) Old 12-29-2017, 04:48 PM Thread Starter
Clutch issue
With my bike on center stand and running, with the clutch in bike runs fine until it reaches fourth, and fifth gear. Fourth and fifth seem to chug and clang a bit however no noise. Also when the clutch is let loose in any gear the bike stalls. this bike is an 02 and i only picked it up a few days ago. Am i in the right direction of it being clutch? I also read several posts about clutch plates sticking - are these the symptoms? I was told trans may be shot from the previous owner - but also read here the trans is very difficult to break. Any help would be great.
Thanks
i should mention that the bikes handle bars are 12 in apes, and new clutch cables were needed if that makes a point i'm not sure
Brooklyn_Vulcan is offline
post #2 of 11 (permalink) Old 12-29-2017, 04:54 PM
check your side stand and clutch switches first for the stalling issue
Brooklyn_Vulcan likes this.
post #3 of 11 (permalink) Old 12-29-2017, 05:11 PM Thread Starter
where would I find the clutch switch- external or internal ?
post #4 of 11 (permalink) Old 12-29-2017, 05:13 PM
external on the clutch lever,where the wires come out of it
post #5 of 11 (permalink) Old 12-29-2017, 05:22 PM Thread Starter
only wires i see is the three prong clip near the clutch handle - thats plugged in. When it's not plugged in the bike won't start at all. Im guessing thats the clutch switch - i hope
post #6 of 11 (permalink) Old 12-29-2017, 07:34 PM
Clutch lever switch seems to be working, since it dies when you release it.
I'd check the sidestand switch. Probably stuck in the 'down' mode. (contacts inside the switch)
post #7 of 11 (permalink) Old 12-29-2017, 07:50 PM
Is this with the bike on the center stand only? Have you tried actually riding the bike?
post #8 of 11 (permalink) Old 12-29-2017, 09:38 PM
if the bike is on center stand, with side stand down, there is no way for the idiot switch circuits to know the center stand is down (there are NO switches for it). if side stand is down, it will shut off ignition as soon as the clutch lever is released.
a little cleaning of the side stand switch fixes the majority of this issue, or bypassing it altogether
michiganteddybear is offline
post #9 of 11 (permalink) Old 12-30-2017, 10:28 AM Thread Starter
hello and thanks for the help - haven't rode the bike yet as i was informed from previous owner if the trans was bad as he thinks - there is a probable that metal fragments could be pushed through the machine - but even if bike was running through gears on center stand wouldn't that cause same issue? Need to drain oil and see what that reads i suppose before i try riding.
He also mentioned that the bike will ride but only with clutch pulled in - said quite annoying but can be done. I myself haven't tried anything off center stand - just incase he aint wrong
post #10 of 11 (permalink) Old 12-30-2017, 12:03 PM
sidestand switch
