Shifting issues - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 8 (permalink) Old 09-26-2017, 12:13 PM Thread Starter
Shifting issues
Hi everyone. I just picked up a vn800 on trade that had been sitting for a long time due to some very minor issues I was able to fix with just some know how. I had to clean and repair the carb. They had the fuel line set to prime and the throttle set to high. Got everything set correctly and it runs great. When I first went to ride it I couldn't get it out of neutral. I walked it up the drive way a few times trying to shift it and it finally went into gear. Ride it for a mile or two and brought it back and parked it til I can get and oil change and tags. Changed the oil today and went to ride it. It was no longer in neutral in won't shift. This is my first bike so I am learning as I go using mainly YouTube but can't figure this one out. Any help would be appreciated.
Qkunk1 is offline
post #2 of 8 (permalink) Old 09-26-2017, 12:26 PM
this forum is based on the 700/750 Vulcan and you probably won't find much information here
post #3 of 8 (permalink) Old 09-26-2017, 12:35 PM Thread Starter
Sorry I didn't realize a vn800 850cc Vulcan was that much different then the 700/750. Figures people who know Vulcan would know the issue
Qkunk1 is offline
post #4 of 8 (permalink) Old 09-26-2017, 02:32 PM
Just because it says "Vulcan" doesn't mean they are mechanically the same.
But for most bikes, if the shift lever is not loose or somehow disconnected from the transmission, failure to shift would likely be a broken or bent shifter fork.
post #5 of 8 (permalink) Old 09-26-2017, 02:53 PM
post #6 of 8 (permalink) Old 09-27-2017, 11:43 AM
ubertalldude's Avatar
In hindsight, seeing how this guy acted, you're too kind Knifemaker LOL
ubertalldude is offline
post #7 of 8 (permalink) Old 09-27-2017, 12:45 PM
How did he act? He had a problem. He wanted to ride his new bike. He is probably bummed that he can't. I know how he feels. I drove a fookin car to work.
post #8 of 8 (permalink) Old 09-27-2017, 12:49 PM
read his introduction
