broke linkage - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 6 (permalink) Old 07-06-2017, 02:54 PM Thread Starter
just crushing along
meathead1465's Avatar
Unhappy broke linkage
well its official this is what i have to repair this was interesting to get this apart.
got most of the gaskets and stuff ordered for to put this back together.
meathead1465 is offline
post #2 of 6 (permalink) Old 07-06-2017, 04:06 PM
Alpha Geek
Hexadecimus's Avatar
Nahh, you don't need to take the cover off just to replace the gask.. HOLY SHEISSE, that sucks man. How did you manage that? I guess it could have been worse; balancers or something. These are good bikes, so don't let that get you down. Good luck!
Hexadecimus is offline
post #3 of 6 (permalink) Old 07-06-2017, 04:12 PM
that looks like the older style linkage. the newer one has a thicker body than the threaded ends if I recall correctly
michiganteddybear is offline
post #4 of 6 (permalink) Old 07-06-2017, 04:14 PM
ubertalldude's Avatar
DAMN! Welp, you're nearly halfway there. Glad you found the problem and that it's reparable (even if it is a PITA)
ubertalldude is offline
post #5 of 6 (permalink) Old 07-06-2017, 06:10 PM
Alpha Geek
BTW, if that threaded rod is expensive to order as a Kawi part, it would be approximately dirt cheap to make or buy as a threaded rod.
post #6 of 6 (permalink) Old 07-07-2017, 03:38 PM Thread Starter
just crushing along
well found one well a thick one that is used like new (the new style) now just have to find head gaskets
dean aka meathead1465
