Spline Lube at 9000 w/Pics - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 9 (permalink) Old 06-21-2017, 12:57 AM Thread Starter
Golf's Avatar
9000 Miles
Two new Pirelli Tires, 90 degree valve stems, will balance with ride-on. Lubed splines and took apart hub to clean and apply grease. I hope my splines aren't too bad, there's shiny metal on the final drive part
ID:	38298   Click image for larger version
ID:	38306   Click image for larger version
ID:	38314   Click image for larger version
<- Slow Down, Move Over ->
Hookin' Ain't Easy
Current Rides
2013 F550 XLT 6.7 Powerstroke (Tow Truck)
2002 Ford Mustang GT Convertible (Too Many Mods)
2003 Ford Mustang GT Convertible (Too Many Repairs - Wife's D/D)
2006 Vulcan 750
Purchased 05/17 8900 miles
R/R Relocated
Voltmeter/USB Charging
K&N Air Filters
Spline Lube
Pirelli MT66 Tires Balanced w/Ride-On
Golf is offline
post #2 of 9 (permalink) Old 06-21-2017, 06:47 AM
Looking good!
post #3 of 9 (permalink) Old 06-21-2017, 09:52 AM
those splines look damn near factory fresh!
michiganteddybear is offline
post #4 of 9 (permalink) Old 06-21-2017, 02:14 PM
yes,almost minty fresh.they don't need any mentos
post #5 of 9 (permalink) Old 06-22-2017, 01:02 AM Thread Starter
Golf's Avatar
I'm worried I made a few mistakes - I didn't line up the dot on the rear tire with valve stem - but I'm balancing with ride-on. A buddy suggested I should have used loc-tite on the bolts. In my personal opinion I think I should have put some type of grease on the axles, but the axles looked really clean, without a ton a grease just a thin film..... It looks like there's a space between the hub and the brake drum... but the hub has to spin free? It just looks like water could get in there... This normal?
Hookin' Ain't Easy
Current Rides
2006 Vulcan 750
R/R Relocated
K&N Air Filters
Spline Lube
Golf is offline
post #6 of 9 (permalink) Old 06-22-2017, 09:29 AM
ubertalldude's Avatar
So long as you lubricated the splines with a good moly grease and tightened everything down properly, you don't need to grease or loctite anything else. No need to worry about the space between the rear drive and the wheel, the assembly is sealed. As for the brake assembly, so long as you got everything aligned properly (it doesn't really go back together otherwise, so you're fine) there is nothing to worry about. Brakes get a little wet, just tap em to dry them off a bit. The rear brake isn't worth much of a damn on these bikes, anyhow.
ubertalldude is offline
post #7 of 9 (permalink) Old 06-22-2017, 09:31 AM
all of what you said is ok, just a thin film of grease on the axle (it has sealed ball bearings to do the heavy work), locktite would be ok, but I dont think its absolutely needed. brake assembly has a very small gap between the wheel (where drum is) and the plate (where the brake shoes and such are). it is free to spin until you reconnect the torque link, that keeps it from spinning when in use. Ride on will work for balancing, the dot on tire is just to indicate where the lightest spot is, to aid in balancing
post #8 of 9 (permalink) Old 06-22-2017, 10:27 AM
yes the dot is the lightest side of the tire.the reason you line it up with the valve stem is that is the heaviest side of the wheel and requires less balancing. I have never had to balance a tire mounting it that way
post #9 of 9 (permalink) Old 06-22-2017, 02:12 PM Thread Starter
Golf's Avatar
I rode it a bit last night, it's been raining a lot so I'll put the rideon in this weekend but I couldn't tell it needed balancing up to 60mph... we'll see
Golf is offline
