Help me figure this out. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
 9Likes
post #1 of 37 (permalink) Old 06-03-2017, 09:22 PM Thread Starter
Earlier this week on my ride home I was on the interstate, going about 65 in 5th when all of a sudden it felt like it jumped into neutral so I pulled in the clutch and got off the road, after getting it into neutral whenever I put it into gear it would bog down and kill the engine if I didn't pull the clutch again
I trailered it home and drained the oil, I checked? the pawl spring and it seems to be okay, my main suspicion and fear is that it is the splines, the PO never lubed them and when I checked when I replaced the rear wheel they were bone dry.
I shot a quick video after I checked the spring and put it back together: https://youtu.be/PXICYgqBIcQ
Any ideas what it might be?
It is a '04 with around 26k miles on it.
Timothy Mitchell is offline
post #2 of 37 (permalink) Old 06-03-2017, 09:33 PM
Ouch. That noise once you got it into gear ... splines is the most likely culprit.
Don't now why the engine would bog though. Seems like it would still either turn the wheel or happily chew up the remnants of the splines.
Vulcan slang for newcomers
Service Manual Download
Thorn is offline
post #3 of 37 (permalink) Old 06-03-2017, 10:07 PM
the engine should rev like the clutch is slipping,should not bog down.that's wierd
post #4 of 37 (permalink) Old 06-03-2017, 10:17 PM Thread Starter
I'll put oil in it tomorrow and record a video of it running
post #5 of 37 (permalink) Old 06-04-2017, 02:40 PM
We don't need a running video. Just take the wheel off and check the splines. Check both the final drive and the bevel gear. It would have been faster to check than to ask us, to be honest.
If it's in neutral you often have to 'rock the bike' to get it to change gears when it's off, similar to what you did. Nothing to worry about there.
If it's not the splines, report back with that video.
Thorn likes this.
post #6 of 37 (permalink) Old 06-04-2017, 08:51 PM
I would like to see a video.there is something more going on then splines.worn splines WOULD NOT make the motor bog down.it should rev up like the clutch is slipping and not move or move slowly.I also don't remember my one differential making noise with bad splines when the wheel was spun.I suppose it could be slipping on the splines making that noise but I think something is binding
post #7 of 37 (permalink) Old 06-04-2017, 09:03 PM
We are here to help.maybe if one of us here knew something to help him,it would be quicker to ask one of us for insight than to jump in over his head without assistance. we are here to help the newbies get and keep these bikes running,not to make ourselves appear superior in our vast knowledge of these machines.
post #8 of 37 (permalink) Old 06-05-2017, 03:01 AM
Matthew Wellington's Avatar
Well said Doc
Matthew Wellington is offline
post #9 of 37 (permalink) Old 06-05-2017, 11:32 AM
Not the splines as doc says. I lost my primary pulley which would be the same as the VN splines and you would be able to normally click into all gears and just not go anywhere. Wouldn't stall.
post #10 of 37 (permalink) Old 06-05-2017, 12:47 PM
glad you got her fixed, Goofyfoot. I may razz ya a little about owning a sporty, but it's all good fun.honestly, I do like sportsters (well,maybe a little )
