Crunchy Grindy Sounds - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
 2Likes
  • 1 Post By T-Bone
  • 1 Post By CKGonzo
post #1 of 10 (permalink) Old 04-25-2017, 02:47 PM Thread Starter
T-Bone's Avatar
For a week now I noticed a new sound. When I accelerate from a stop I hear a sound that at first I thought was the rear wheel spinning on road grit. Now I think it's coming from the clutch or transmission. I just checked and re-greased the spline, so it's not that. Does this ring any bells with the members?
T-Bone is offline
post #2 of 10 (permalink) Old 04-25-2017, 02:53 PM
Is it only the first few accelerations of the day, or every single one?
When cold, the clutch can cause a grindy noise called the coffee grinder noise. You can find tons of threads on it. A solution is to drill the clutch basket.
post #3 of 10 (permalink) Old 04-25-2017, 02:54 PM
ubertalldude's Avatar
try rolling the bike around in the garage to see where it's coming from, or you can put the bike up on the centerstand and get the rear tire off the ground and spin it freely
my first thought might be that u-joint where the bevel gear comes out of the engine and goes into the shaft tube, that area can get pretty greasy if the rubber boot is undone
ubertalldude is offline
post #4 of 10 (permalink) Old 04-25-2017, 03:51 PM
I agree on the coffee grinder syndrome (CGS)
michiganteddybear is offline
post #5 of 10 (permalink) Old 04-26-2017, 08:35 AM Thread Starter
T-Bone's Avatar
Thank you. I'll try to pay closer attention, but now that I think about it, I'm pretty sure that it only happened in my driveway and the parking lot at work.
T-Bone is offline
post #6 of 10 (permalink) Old 04-26-2017, 11:16 AM
yup.coffee grinder syndrome.
post #7 of 10 (permalink) Old 04-28-2017, 04:14 PM Thread Starter
T-Bone's Avatar
I can confirm that it is just when the bike is cold. Thank you for the advice. I looked up the clutch basket drilling procedure and it looks pretty straightforward. Something to do on a rainy weekend!
Thanks again!
thtanner likes this.
T-Bone is offline
post #8 of 10 (permalink) Old 04-28-2017, 05:28 PM
Thanks again!
Just so you know, there's no proof that anything is getting hurt when this happens. Most will say if you let the bike warm up well before you take off, and while doing so squeeze the clutch lever in a bunch of times, it rids or lessens the noise.
I put in a Kevlar clutch...(not to cure the issue)..and the noise went away ....for about a year.
Many just live with it....
post #9 of 10 (permalink) Old 04-28-2017, 05:39 PM
Yeah I don't think it causes too much issue, maybe a bit of extra wear on the clutch plates at most. It's also embarrassing in a parking lot, haha.
I idle for a min or two and pull in my clutch a bunch before the first take-off.
post #10 of 10 (permalink) Old 04-29-2017, 02:20 PM
CKGonzo's Avatar
Same here with the grinder noise. Mine will also grab when engaging the clutch from a dead stop. Just have to be mindful when pulling away for the first few miles.
Sent from my iPad using Tapatalk
Current: 2004 VN750
Former: 1989 VN750, 1978 Honda CB250
Back in the saddle again after sacrificing my ride for my kids in 1994!
CKGonzo is offline
