Final drive stuck in coupling during removal. Need Help - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
 3Likes
post #1 of 17 (permalink) Old 02-20-2017, 08:15 PM Thread Starter
Exclamation Final drive stuck in coupling during removal. Need Help
I bought my 2004 VN750 this past July and she has been running great! The previous owner apparently didn't know the importance of keeping the splines lubed up and the final drive oil healthy. I was taking off after a stop light and heard a POP and lost power. With the clutch pulled and the bike in first it sounds like the teeth in the coupling are grinding the teeth from the final drive. If i leave it in first and shut the bike off i can move the bike freely forward and back and clearly hear the sound where the driveshaft meets the final drive.
So now for the issue. Today I took the back tire off and unbolted the final drive. When I tried to pull it off the final drive would not come out of the coupling. The only give it had came from the ujoint sliding off of the shaft that goes to the tranny. I put some good force into tugging on the final drive but it would not come out of the coupling.
Anyone have this issue or have any advice?? Any and all help is appreciated!
Thanks, Bradyn
boitker is offline
post #2 of 17 (permalink) Old 02-21-2017, 10:23 AM
Big hammer?
Sounds like the high spots have mated together. You could try starting the bike and getting it to spin off.....
post #3 of 17 (permalink) Old 02-21-2017, 12:36 PM
Big hammer?
yea,that sounds like a FUN idea...
Spockster and Hexadecimus like this.
post #4 of 17 (permalink) Old 02-21-2017, 04:19 PM Thread Starter
I used a 2 foot long lead pipe to get a good angle and then hit the top of that with a 5 pound hammer. I couldn't get it to budge. I'm hoping i don't have to cut the coupling.
boitker is offline
post #5 of 17 (permalink) Old 02-21-2017, 04:43 PM
Could try putting the rear back together loosely, with just a bolt or two, put the wheel back on ... then with the trans in gear, try turning the rear wheel backward, trying to get the splines to slip off where they're jammed, or realign with good splines if there are any.
Also might need to bump the shaft forward a little, in case the pulling rearward has jammed it tighter. (before putting the bolts or wheel on)
post #6 of 17 (permalink) Old 02-23-2017, 03:16 PM Thread Starter
I'll give that a try! Thanks for the advice!
boitker is offline
post #7 of 17 (permalink) Old 02-23-2017, 08:18 PM
Seems like the New owner didn't know the importance either, lol. That's one of the things I've done with every one of these bikes I've bought & sold is to check the splines. Costly lesson, hope you get back on the road and enjoying it soon.
post #8 of 17 (permalink) Old 02-28-2017, 02:59 PM Thread Starter
Indeed, but now I know
boitker is offline
post #9 of 17 (permalink) Old 02-28-2017, 04:10 PM
Retired USAF (IYAAYAS)
Chris and Shim's Avatar
I wonder if it could be as simple.... naw, can't be! When you finally do get it separated, check the mating surfaces where the final drive mates up to the drive shaft housing. There shouldn't be anything there. But, if some bozo in the past put some Permatex-type gasket sealer there then that could be contributing to it being stuck. (It would have to be some serious gasket sealer!) There is no need to seal it at all but, ya never know. Once again I am thinking something that shouldn't be, but, life gets weird sometimes. Is there any kind of separation at all between the final drive and drive shaft housing? I wasn't quite clear on if it was flat out stuck together or separated by a smidgeon but won't release any further. Spockster has a good idea about seeing if you can nudge the driveshaft forward. I like to check easy stuff first so also verify that there is not a washer stuck on one of the four bolts preventing it from sliding out. There shouldn't be but you'll feel like a doofus later if it IS something simple like that. I've been a doofus many times because I would skip over simple answers, thinking something was more complicated than it actually was.
Saddlebags, hard mounted
Fork mounted tool bag (now hard mounted)
Relocated rear turn signals
LED turn signals, brake lights and running lights
LED license plate frame
Engine Guard and Highway pegs
National Cycles Low Boy Heavy Duty windshield
Home made lowers (nice)
Custom seat (made by a local guy)
Iridium plugs (DPR7EIX-9)
Shenko 230 Tour Master tires at 11,123 miles
Splines lubed at 11,123 miles
Luggage rack
Light bar with LED lights
Progressive 412 shocks
Chris and Shim is offline
post #10 of 17 (permalink) Old 02-28-2017, 11:00 PM Thread Starter
I finally got it off! It took about 20 minutes with a lead pipe, a sledge hammer, and a trusting friend. I'll upload pictures of the splines and couplings, they are beyond shot. Thanks for all the comments and support through this interesting predicament! Send anyone who needs to see how bad splines can get here!
boitker is offline
Tags
final drive , replacement , spline , spline lube , transmission noise
