Shifter Shaft Problem - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
 2Likes
  • 1 Post By Thorn
  • 1 Post By mcinturff
post #1 of 8 (permalink) Old 09-24-2016, 05:56 AM Thread Starter
mcinturff's Avatar
My shift shaft moves in/out 3/4" to 1". Am I missing a circlip or something? All I see when the stator cover is off is a washer, I believe there might be a circlip behind it, but maybe there's one on the inside of the motor to restrict movement?
Engineer/Motorcycle Junkie
Junction Box Bypass:
https://www.vn750.com/forum/19-electr...-problems.html
mcinturff is offline
post #2 of 8 (permalink) Old 09-24-2016, 06:27 AM
There should be two circlip/washer pairs on the shifter shaft under the stator cover.
From the outside in, it should be: shift lever spline, washer, circlip, section of shaft through empty space, circlip, washer, engine wall (leading to another cavity on the other side)
If both circlips are in place there shoudn't be an inch of play. There are grooves on the shaft for the circlips, so you should be able to tell where they go even if they're missing.
mcinturff likes this.
Vulcan slang for newcomers
Service Manual Download
Thorn is offline
post #3 of 8 (permalink) Old 09-25-2016, 07:48 PM Thread Starter
mcinturff's Avatar
So I pulled the cover back off after cleaning the engine, and the washers and circlips are all there. However, the shaft won't out far enough to get the inner circlip back in its groove. I'm wondering if the shaft got moved in and can't move back out because of interference with another part. Hopefully it's not the oil pump chain guide. Any ideas?
post #4 of 8 (permalink) Old 09-25-2016, 09:00 PM
Was the bike ever dropped? There is a piece that can bend a bit in there, but still function fairly normally
post #5 of 8 (permalink) Old 09-25-2016, 09:10 PM Thread Starter
mcinturff's Avatar
It appears to have been dropped on the right side, but not the left. I think it would still function fine if I left it alone, it just bugs me having movement in that shaft. I could add a collar/spacer on there so the shift lever doesn't rub the frame. At least it still shifts fine.
thtanner likes this.
post #6 of 8 (permalink) Old 09-25-2016, 09:11 PM Thread Starter
mcinturff's Avatar
It's damn close too. If I could pull that shaft 1-2mm more I could get that circlip back on.
post #7 of 8 (permalink) Old 09-26-2016, 12:17 AM
Are you talking the shift linkage rod? If it bent sideways it could rub against the housing...
Hate to say it 'cause you probably already know it, but don't use force! A sleeve spacer sounds like a pretty good alternative to splitting the engine to see what it's hanging on on the other side.
Thorn is offline
post #8 of 8 (permalink) Old 09-26-2016, 12:39 AM Thread Starter
mcinturff's Avatar
Looking at the 4 minute mark onward in this video, it doesn't seem like there would be anything holding it back except the oil pump chain guide.
