Shifter pedal loose - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
 8Likes
post #1 of 17 (permalink) Old 06-04-2016, 04:37 PM Thread Starter
Shifter pedal loose
See video:
Noticed recently that shifting has gotten harder, on and off. Sometimes it's normal, other times it requires a lot more effort.
Checked the shifter just now and it has a lot of play in and out. Anyone experienced this before? I assume that when it's all the way out, it's harder to shift, and vice versa.
My bikes:
2017 Kawasaki Z1000SX Tourer
2002 Suzuki DR-Z400S
1999 Yamaha Dragstar 1100
Python is offline
post #2 of 17 (permalink) Old 06-04-2016, 05:28 PM
There are two thin washers that ride on the shifter shaft inside the case. Their purpose is limiting in/out travel of the shaft.
Either yours have broken off, or someone has left them out when the engine was taken apart. It's easy to miss the outer one when it drops out as the case is removed.
Some have used a piece of rubber fuel hose slid over the shaft to limit travel to the inside. You may find posts about here if you're lucky with the search. Not sure how you could limit the outward travel, however. Outward may not be a problem, try the hose for a temporary fix.
What is happening, the internal linkage hits other internal parts of the engine/trans when the shaft slides out of place.
WilliamTech and Python like this.
post #3 of 17 (permalink) Old 06-05-2016, 06:19 AM Thread Starter
Thanks for replying.
Doesn't sound as bad as I feared, at least.. Is it risky to ride it around when it's like this?
My bikes:
Python is offline
post #4 of 17 (permalink) Old 06-05-2016, 11:23 AM
Exclamation
Not sure, but could be. If you can't get through the gears reliably, I'd be careful pulling into traffic.
I'm always leery of anything that can cause catastrophic engine failure while riding. Just not sure what sort of interference the internal linkage can cause.
I would at least get a piece of hose on there to eliminate half of the problem.
I'll see if I can find a post on it so you'll know what length to try.
edit: Going by the posts I found, a spacer on the outside will let it shift reliably. Here's some links, including the search I used, and one picture link.
Rubber hose, rubber washers, plastic spacers, pvc pipe, or a hose clamp have all been used with success. Hose clamp may tend to wear on the case. Looks like 1 1/16" is the length used for a spacer.
Search:
https://www.vn750.com/forum/gtsearch....755j8755339j12
Pics:
http://s652.photobucket.com/user/tou...tml?sort=6&o=4
https://www.vn750.com/forum/26-transm...de-play-2.html
https://www.vn750.com/forum/26-transm...ter-pedal.html
https://www.vn750.com/forum/26-transm...e-shifter.html
Python likes this.
post #5 of 17 (permalink) Old 06-05-2016, 03:48 PM
Read this
https://www.vn750.com/forum/26-transm...s/18271?page=1
Python likes this.
post #6 of 17 (permalink) Old 06-05-2016, 04:25 PM
YES ! Precisely true. I performed this fix. No need to remove Shift Pedal.........Split rubber hose is about 1 1/4" long holding shaft outward with maybe 1/8" in-outward free-play remaining ........works like a champ !
Many K miles with this DIY Fix.
post #7 of 17 (permalink) Old 06-05-2016, 05:12 PM Thread Starter
Search:
This is a discussion forum for the Kawasaki Vulcan VN750 and VN700 - Search Results for shifter play
Pics:
Plastic Spaces Close Up Photo by tourmax | Photobucket
Wow, thanks a lot. I'll try to fix it next weekend. Really appreciate the help.
From the thread: "If all you did was knock off the clip inside the case, you can just pull the lever so it is as far out as you can pull it , then measure the space between the shifter lever and the case.
You just need to take off the shifter and install a spacer or a stack of washers that are add up to that measurement to keep the shifter from moving in towards the engine case."
So basically, the shifter is supposed to be all the way out? I thought it was the other way.
My bikes:
Python is offline
post #8 of 17 (permalink) Old 06-05-2016, 06:39 PM
Not sure if I would pull it out all the way. Maybe try the 1 1/16" to 1 1/4" spacer mentioned in the threads.
post #9 of 17 (permalink) Old 06-05-2016, 09:21 PM
Yup that's what I'd do
post #10 of 17 (permalink) Old 06-06-2016, 12:04 AM Thread Starter
That means I have to open the cover, drain the oil etc so I can install a spacer in there?
Edit: "If all you did was knock off the clip inside the case, you can just pull the lever so it is as far out as you can pull it , then measure the space between the shifter lever and the case.
From one of the threads. Seems like people in that thread recommended pulling it all the way out, then installing a boat load of washers, copper pipe, pvc pipe etc. Whatever that would hold it out - and let it have a little bit of play.
Sorry if I'm nagging, haha, but I'm just a month away from a very long trip where I'm visiting 3 countries. Kinda nervous doing this on an old ass bike, so I want it to be as tip top as possible.
My bikes:
Python is offline
