Transmission shot.....I think - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
 1Likes
post #1 of 22 (permalink) Old 06-01-2016, 08:46 PM Thread Starter
Unhappy Transmission shot.....I think
I have a 1994 vn750. I recently was driving my bike and just pulled out of a parking lot and shifted into 2nd. I tried to accelerate and I was just revving the engine. I thought I hadn't shifted high enough and got stuck in neutral. I shifted again and the same thing happened. I pulled over and learned that something in my transmission was terribly wrong. Nothing happened while I was sitting in Neutral but once I shifted into gear there is a loud grinding noise. I am fairly new to motorcycles and am trying to find videos and other resources to use to fix this myself. How big of a fix does this sound like? What is the likely cause of this? I could take it to a shop but I feel I would be paying more than I bought it for to fix the transmission. Any help would be appreciated!!!
rogasaki is offline
post #2 of 22 (permalink) Old 06-01-2016, 08:56 PM
the tranmissions in these are very durable... the splines on the rear drive... not so much..
im betting rear splines are destroyed..
check the verses for the spline lube procedure, it will allow you to inspect them, and see if you have a bunch of rust colored dust instead of nice lubricated splines
michiganteddybear is offline
post #3 of 22 (permalink) Old 06-01-2016, 09:02 PM Thread Starter
Thanks for the input. I will check that out. How big of a cost would it be to replace the rear splines if it was the cause?
rogasaki is offline
post #4 of 22 (permalink) Old 06-01-2016, 09:40 PM
If you watch ebay you can find driveshafts around $20 and final drives at $50-80. Of course many get listed a lot higher too.
post #5 of 22 (permalink) Old 06-01-2016, 09:43 PM
Also you gotta watch ebay, some salvage yards don't know what a good spline on a final drive looks like. There's one on there now that looks like it's shot. If you have any questions just post it on here and we'll let you know what we think.
post #6 of 22 (permalink) Old 06-02-2016, 09:38 AM
right, if you find one on ebay your interested in, post a link to it, we can help determine if its a usable part
post #7 of 22 (permalink) Old 06-10-2016, 01:37 PM Thread Starter
Splines Update
Alright I think the splines look to definitely be the problem but to my knowledge the coupling doesn't look that bad. I have attached photos of the parts from my bike. Any input would be appreciated. Thanks
ID:	32386   Click image for larger version
ID:	32394   Click image for larger version
ID:	32402   Click image for larger version
rogasaki is offline
post #8 of 22 (permalink) Old 06-10-2016, 02:07 PM Thread Starter
Replacement final drive
Here is a replacement final drive I am looking at, only charging $50 for it and it is from an '86. Look any good?
1986 Kawasaki Vulcan VN750 K536 Final Drive Rear Differential Diff | eBay
rogasaki is offline
post #9 of 22 (permalink) Old 06-10-2016, 03:54 PM
Both are toast,imo
post #10 of 22 (permalink) Old 06-10-2016, 04:19 PM
If you look in the coupling you will see it's ground down. The outer most part is the only thing left. Yes, both shot.
