Wont go into 2nd on up - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
 3Likes
post #1 of 13 (permalink) Old 05-12-2016, 08:41 PM Thread Starter
Felicia Priestley's Avatar
I have a 2003 VN750. I have forward controls on it and while out riding the shifter came apart and hit the road while crusing about 60 well i pulled over shut the bike off and started looking around for the bolt and bushings that went missing could find them so only being like 3 miles from the house i just put put back in first gear. well it down shifted from 5th to 1st no problem at all no bind nothing hard with it at all. When i got back home i put my stock shifter back on and all it does is goes from 1st to neatural and back to 1st is all i can do it will not go into 2nd at all can anyone please help us out
2003 6k miles
Felicia Priestley is offline
post #2 of 13 (permalink) Old 05-12-2016, 09:45 PM
1st,Is it running when you try to shift into second? I'm asking cause it won't shift into second unless its rolling at a certain speed.
2nd.ls the shifter hitting on something not letting it shift up?if that is the case just pull it off and move it a few splines
WilliamTech likes this.
post #3 of 13 (permalink) Old 05-12-2016, 09:46 PM
Someone FAR more experienced and knowledgeable will answer very shortly I am sure.
Was it hard to put into 2nd and higher gears or even after the incident by chance? Are you using more foot pressure now to get into first relative to when you first got the bike? Reason I asked is I could not get my bike into 2nd right before I experienced shift rod failure and the excessive force of my foot finally did it in. Hopefully your issue is something different.
I am sure someone will have some have good tips [EDIT: just like above for something simpler :-)]. If not, you can remove the trans cover, the one with the oil level sight glass to see the pawl and shiftdrum end to see how engagement is, the Positive Neutral Finder would prevent you from moving into 2nd unless you fool it though.
2002 vn750
AGM battery, Shinko 230 tires oversized front
Ear shaved - k&n pods, drilled clutch basket
40/138 jetting
If I can split a case and make it work - you can too!
Forum pictures:http://s150.photobucket.com/user/Gid...?sort=3&page=1
gidaeon is offline
post #4 of 13 (permalink) Old 05-12-2016, 10:08 PM Thread Starter
Its not hitting anything at all and i tried in the drive way and at 30 mph just wont go i even put it on the center stand and was trying and its not hard at all to go in first its very easy before and after the the problem
2003 6k miles
post #5 of 13 (permalink) Old 05-12-2016, 10:29 PM
double check that the stock shifter isnt hitting the frame or something.. clearances there are kinda tight, and its easy to put it on a spline or 2 off. that will keep it from shifting into higher gears
Thorn likes this.
michiganteddybear is offline
post #6 of 13 (permalink) Old 05-12-2016, 10:56 PM
I would still try moving the shifter
post #7 of 13 (permalink) Old 05-13-2016, 10:32 PM Thread Starter
i did take yall advice and moved the shifter down it still did i brought it to a friend that rides and works on bikes and droped off a case of beer and 100 bucks and told him to fix it he called me at lunch today told me the little rod inside got bend some kind of way but lucky me he had one that he had for a spare for his 06 vn750 he had and told me it should be back up by midnight to 2 am today so crossing the fingers hoping to take it out tomorrow to go to a bike blow out/ crawfish boil in new orleans, Louisiana
thtanner likes this.
2003 6k miles
post #8 of 13 (permalink) Old 05-14-2016, 12:26 AM
Cool.good to hear
post #9 of 13 (permalink) Old 05-14-2016, 04:08 PM
i did take yall advice and moved the shifter down it still did i brought it to a friend that rides and works on bikes and dropped off a case of beer and 100 bucks and told him to fix it he called me at lunch today told me the little rod inside got bend some kind of way but lucky me he had one that he had for a spare for his 06 vn750 he had and told me it should be back up by midnight to 2 am today so crossing the fingers hoping to take it out tomorrow to go to a bike blow out/ crawfish boil in new orleans, Louisiana
Wow....A GREAT Deal ! - -
ps;Take it easy on the shift pedal...Do Not Stomp.
post #10 of 13 (permalink) Old 05-18-2016, 09:57 AM
I thought that little rod inside required a complete engine teardown to replace?
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
