"Fortified" moly greases commonly available - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
 1Likes
post #1 of 23 (permalink) Old 04-26-2016, 02:51 PM Thread Starter
I bougt some generic ep moly grease to do spline lube and realized many guys are buying expensive tubes online. I presume that is so you have a known moly percentage instead of unknown?
I am expecting its recommended i return this since its a unknown amount of moly fortification. I checked several auto parts stores.
gidaeon is offline
post #2 of 23 (permalink) Old 04-26-2016, 02:57 PM
calebj's Avatar
If you're going to be regularly replacing it, IMO it's fine (it's not as if the splines had -any- lube from the factory on a lot of the 750's). However, the Moly 60 specified is designed to be able to sit on the splines and last for years without liquifying and coming off. I wouldn't sweat it, but then again, I also chose to get the more expensive stuff so maybe I'm being hypocritical.
1986 VN750 27k miles
1999 EN500 32k
1983 GL650i in pieces. Someday it will ride again.
calebj is offline
post #3 of 23 (permalink) Old 04-26-2016, 03:24 PM
pretty much what I was gonna say..
however, I was gonna say it like this:
"Any lube on the splines is better than NO lube, which results in powdered rust colored metal"
michiganteddybear is offline
post #4 of 23 (permalink) Old 04-26-2016, 04:34 PM
Drew M.'s Avatar
i know the Honda 60 is what everyone recommends here. however, i was unable to find it. i did find a Locktite Moly Paste on Amazon. it was $24 i think. i seem to recall that the bottle said it was 65% moly and it had pretty good reviews.
of course if you are going to replace it more than every 10,000 miles something that is only 30% is going to be fine.
Drew
'03 VN750 a little over 4300 miles
Spline lube
F&S Rear blinker relocation
F&S Luggage rack
Saddlebags
F&S Extended backrest
Mustang seat
F&S Engine guard
Plexifairing 3 windshield
KM style dash
LED everything + additional brake lights &
LED plate bolts
Drew M. is offline
post #5 of 23 (permalink) Old 04-26-2016, 06:34 PM
Expendable newbie
evulcannibal's Avatar
I used Valvoline synthetic blend grease. I couldn't find moly and figured that using Valvoline grease was better than leaving it all dry and rusty.
Don't take my word for it. I'm just a foolish newbie.
When in doubt, just know that I am only joking around.
95 VN750
Top speed is 112 mph at ~7900 rpm
Blacked out engine
Dry rusty splines finally lubed for the first time
R/R relocated to the side of fuse box
Rust removed from tank
In line fuel filter, 23-28 micron rating
Gear indicator
LED turn signals & brake light
16 color LED engine light up & underglow
evulcannibal is offline
post #6 of 23 (permalink) Old 04-26-2016, 08:15 PM Thread Starter
I may use the cheap moly i have for now (Not sure how long i will keep bike assuming this venture does indeed go go well.. And lube job is much easier compared to rest of work happening haha)
The u joint and gear out of bevel were lubed! The final drive of course was dry with rust. :-( How bad does final drive look for wear? Useable?
ID:	31393   Click image for larger version
ID:	31401   Click image for larger version
gidaeon is offline
post #7 of 23 (permalink) Old 04-26-2016, 08:21 PM
Just in the nick of time, but ok. Flush all that dust out even if you have to use water, it acts just like sand.
post #8 of 23 (permalink) Old 04-26-2016, 09:51 PM Thread Starter
Will do - with brake cleaner
gidaeon is offline
post #9 of 23 (permalink) Old 04-26-2016, 11:04 PM
Don't do moly. Drugs are bad,m'kay
post #10 of 23 (permalink) Old 04-27-2016, 12:21 AM
Mod
Birdhunter02's Avatar
You can buy the moly at any Honda dealership. Not too pricey.
2003 1600 Classic
Sold
900 Seat Mod
Iradiun Plugs
V and H Cruzers
Windshield with Lowers
LED Tail Lights
Saddle bags
Chads Floor boards
Highway pegs
Birdhunter02 is online now
