Clutch relese lever - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 4 (permalink) Old 04-26-2016, 12:54 PM Thread Starter
dgulley21's Avatar
Clutch relese lever
Have any of you removed the rack and the lever from inside the front bevel gear and then reinstalled it? Does the rack need to rest against the internal push rod snug?
dgulley21 is offline
post #2 of 4 (permalink) Old 04-26-2016, 02:08 PM
Haven't had it apart, but I think that happens when the lever is put on the splined shaft (outside of the case). You're supposed to rotate the shaft a certain direction until it stops, then align the mark on the shaft with the gap in the lever and install it.
Check the manual for lever installation.
post #3 of 4 (permalink) Old 04-26-2016, 02:15 PM
thats pretty close to how you set it up
michiganteddybear is offline
post #4 of 4 (permalink) Old 04-26-2016, 05:19 PM Thread Starter
dgulley21's Avatar
I appreciate the help. What i thought just wanted to hear it from someone else.
