Need help - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
 5Likes
post #11 of 31 (permalink) Old 04-24-2016, 01:51 PM
Originally Posted by Lyndon View Post
is it normal on these bikes for the clutch to be noisy and rattle.
Are you speaking of a coffee grinding clutch noise ?
If so, Only happens when Oil is COLD .....
What weight Oil are you using ?
post #12 of 31 (permalink) Old 04-24-2016, 01:53 PM Thread Starter
Lyndon's Avatar
10 w 40
Lyndon is offline
post #13 of 31 (permalink) Old 04-24-2016, 02:08 PM
10 w 40
- - Good Stuff ! - - -
post #14 of 31 (permalink) Old 04-24-2016, 02:11 PM Thread Starter
Lyndon's Avatar
haha yeah. so do you have to pull the engine to get in the transmission.
Lyndon is offline
post #15 of 31 (permalink) Old 04-24-2016, 02:22 PM
Whoops haha I meant foot. Sorry for not spell checking. Also why would I post in a vn750 forum if I had a vespa. This is the only issue I'm having. If there was more I would have posted more. The bike is an 87 vn750 it's having an issue with popping out of gear in 5th. Just looking for some help. The bike only has 17000 miles. I'm new to bikes but I am a diesel tech. So I have most of the tools I would need. Does the engine have to be pulled for any trans work. Also new issue today. I was parking the bike and went to put it in neutral and it went to 2nd gear. Then I could only go to neutral and not first. Let it sit then got it to go to first.
Cause vespas are cooldon't mind me I'm a funny foother sometimes
post #16 of 31 (permalink) Old 04-24-2016, 02:24 PM
Yup...then pull the chains, jugs, pistons and split the cases....
post #17 of 31 (permalink) Old 04-24-2016, 02:27 PM Thread Starter
Lyndon's Avatar
make a chopper vespa haha
Lyndon is offline
post #18 of 31 (permalink) Old 04-25-2016, 10:47 AM Thread Starter
Lyndon's Avatar
could this issue be a clutch? it started when i passed a truck on the highway. but it was slipping before so i adjusted the clutch cable.
Lyndon is offline
post #19 of 31 (permalink) Old 04-25-2016, 02:03 PM
A slipping clutch would make the rpm's increase in fifth but pulling up on the shifter would have no effect. Are you letting off the throttle when you pull up on the shifter?
post #20 of 31 (permalink) Old 04-25-2016, 02:11 PM
Try going up a hill in fifth at about fifty mph. Keep a steady speed then crank the throttle. If it revs up,DON'T touch the shifter but let off the throttle and see if it acts normal.another test of the clutch, BUT DON'T DO IT OFTEN, pull in clutch AND front brake.let out clutch like you are starting out.by the way, do this in a dry paved parking lot.if bike resists and stalls out,clutch should be fine.if bike doesn't move and revs up,clutch is slipping
WilliamTech likes this.
