Splitted crankcase twice. Not shifting using the pedal. Too big gap -shaft and cam? - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
 1Likes
post #11 of 25 (permalink) Old 04-15-2016, 10:52 PM Thread Starter
Ok, understood.
At :45, looking at the pawl and it's slot in the center, when you shift, the pin in the center contacts the bottom of the slot and it shifts.
Right after that, when you try to shift the other direction, it doesn't look like the pin contacts the top of the slot. That's when it won't shift.
I'm wondering if the internal linkage rod could be bent or out of adjustment (if any). ??
Maybe shift some more and verify if that pin can ever contact the the top of the slot. ??
Doesn't look like it's throwing the pawl far enough in that one direction. The shift drum and gears appear to be fine from this angle.
New video:
It's not a problem shifting from 2nd to 3rd to 4th to 5th with the pedal. (Of course I need to help a little bit to turn the outputshaft.
ihlebek is offline
post #12 of 25 (permalink) Old 04-15-2016, 10:58 PM
Chucklehead
dragon159's Avatar
Almost looks like what happened to me. If while sitting you can shift into first but not back to neutral, the shift linkage is adjusted too long. Took me three case splits and bothering a friend for three weeks to discover it. In a nut shell the linkage hits the inside of the case and cannot move the pawl far enough to upshift. Possibly in the last split it could have become mis-adjusted. Sorry to say but the only fix is another splitting if I'm right. I hope I am wrong.
"Squirrel Bike" aka Jersey
Rat bike with a good PR agent
shaved and coastered
2 into 1 exhaust
rear 170 and front 110
custom dash with voltmeter
Spitfire windscreen
Plutonium plugs
More to come
dragon159 is offline
post #13 of 25 (permalink) Old 04-15-2016, 11:11 PM Thread Starter
Thanks for the reply!
Ok, but in my case I have no problems shifting from 1st to N
Shows best in this video, I think. (0:54)
ihlebek is offline
post #14 of 25 (permalink) Old 04-15-2016, 11:55 PM
The first video showed it not shifting into 2nd from 1st, but you aren't trying that in the second video. Only 2 through 5 and back, which looks like it's ok there..
As dragon said, doesn't look like enough throw to get into 2nd. Internal rod hitting the case, I remember his post about that..
post #15 of 25 (permalink) Old 04-21-2016, 12:19 AM
Dragon is right i talked him through this issue a while back the reason why you can go from 1st to neutral is that it is a short throw basically a half shift you are going to have to split the case and remove the nut that holds the shift shaft to the transmission so you can rotate the shaft a bit basically re-homing the shift linkage
I promise you this if you split the case and do the same test you did in the video while watching the internal portion of the shift linkage you will clearly see the problem it is a pain in the ass but overall since you have already split the case twice you should find it easier than ever
post #16 of 25 (permalink) Old 04-21-2016, 12:51 AM
RoadHopper's Avatar
Uh-oh....
Are you trying to shift to second with the bike just sitting there? Or did you have trouble when riding the bike?
Just sitting ... Kawi has positive neutral finder, will not go into 2nd unless the bike is moving a certain speed.
Does that also not shift if the RPMs are too high? If i wind a bit much out of first before shifting, sometimes it just blocks as if a brick wall was on top of the pedal.
RoadHopper is offline
post #17 of 25 (permalink) Old 04-21-2016, 01:17 AM
That is just gears not meshing right due to over rev which I doubt I have to tell you but here it is anyway over reving the engine is not a great practice and will accelerate the clock on engine wear
post #18 of 25 (permalink) Old 04-21-2016, 03:13 AM
RoadHopper's Avatar
I usually like to be in 2nd gear before the other side of the intersection. Life doesn't always make that possible depending on various moving things and which direction they are heading.
post #19 of 25 (permalink) Old 06-23-2016, 06:37 PM
ihlebek, just wonderinf if you got this fixed and are enjoying the bike?
2002 vn750
AGM battery, Shinko 230 tires oversized front
Ear shaved - k&n pods, drilled clutch basket
40/138 jetting
If I can split a case and make it work - you can too!
Forum pictures:http://s150.photobucket.com/user/Gid...?sort=3&page=1
gidaeon is offline
post #20 of 25 (permalink) Old 08-24-2017, 10:59 AM
Did anyone ever figure this out? Just rebuilt my entire motor only to go on a test ride and find it doesn't shift into second. But shifts with pliers fine. And the pawl hits the drum like it wants to shift, just like his!
Colt Spoltman is offline
Tags
cam , drum , shaft , shift
