Sea foam in Final Gear? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
 5Likes
post #1 of 17 (permalink) Old 04-12-2016, 04:32 PM Thread Starter
Expendable newbie
evulcannibal's Avatar
With all this talk about sea foam, I was just wondering.
Can sea foam be put into the final gear case? If you pour it in with the final gear oil, will it clean it or is it a bad idea, and why so?
Just a hypothetical question here.
Don't take my word for it. I'm just a foolish newbie.
When in doubt, just know that I am only joking around.
95 VN750
Top speed is 112 mph at ~7900 rpm
Blacked out engine
Dry rusty splines finally lubed for the first time
R/R relocated to the side of fuse box
Rust removed from tank
In line fuel filter, 23-28 micron rating
Gear indicator
LED turn signals & brake light
16 color LED engine light up & underglow
evulcannibal is offline
post #2 of 17 (permalink) Old 04-12-2016, 04:35 PM
calebj's Avatar
Is the final drive dirty?
1986 VN750 27k miles
1999 EN500 32k
1983 GL650i in pieces. Someday it will ride again.
calebj is offline
post #3 of 17 (permalink) Old 04-12-2016, 04:36 PM
Not necessary. Never saw sludge or bad varnish in a gearset running gear lube.
post #4 of 17 (permalink) Old 04-12-2016, 04:47 PM Thread Starter
Expendable newbie
Well like I said, this is just more of a hypothetical question. I don't think the final drive would normally be dirty unless its super old or if someone pour in dirt.
95 VN750
Blacked out engine
Gear indicator
post #5 of 17 (permalink) Old 04-12-2016, 05:50 PM
I don't think it would hurt it...but as the final drive contains such a small volume of oil in the first place, you wouldn't want to put in much more than a tablespoon of Seafoam...if that.
Save the Seafoam for your tank and just change the oil in the drive and refill ....with synthetic oil.
WilliamTech likes this.
post #6 of 17 (permalink) Old 04-12-2016, 06:14 PM
RoadHopper's Avatar
What weight?
RoadHopper is offline
post #7 of 17 (permalink) Old 04-12-2016, 06:37 PM Thread Starter
Expendable newbie
The manual says SAE 90 when above 5 C (41 F), SAE 80 when below 5 C (41 F).
I just use Mobile 1 synthetic gear oil. It is 75W-90.
The final gear takes so little that I drain and refill it multiple times just to kind of flush it out.
WilliamTech and RoadHopper like this.
95 VN750
Blacked out engine
Gear indicator
post #8 of 17 (permalink) Old 04-13-2016, 10:16 AM
Originally Posted by RoadHopper View Post
What weight?
Have you not downloaded a manual yet?
http://www.mediafire.com/?nscb5f0c9zgksnq
post #9 of 17 (permalink) Old 04-13-2016, 11:33 AM
We don't need no steekin manual
post #10 of 17 (permalink) Old 04-13-2016, 11:36 AM
We don't , but.....Some do.....
