oil leak on (clutch shift ?) - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 2 (permalink) Old 01-01-2016, 01:16 PM Thread Starter
rev it up's Avatar
oil leak on (clutch shift/gear change?)
Search the site to no avail (or i don't understand)
Anyone know if i can change this oil seal by simply removing the cable clamp, prying the seal out and push new seal in all from the outside without interfering with anything else ?. oil leaking where finger pointing on photo. thank you.
ID:	26938   Click image for larger version
AGEING IS INEVITABLE,,MATURING IS OPTIONAL
VN 750 A8 1992.
27000 miles.
Imported from California
to UK in 1996.
New for 2012.
new filters(foam type)
replacement shocks(MDI)
Iridium plugs.
AGM battery(platinum)
brake pads(Kyoto)
(All on and running)
rev it up is offline
post #2 of 2 (permalink) Old 01-03-2016, 07:23 PM Thread Starter
rev it up's Avatar
ok. Found some info !. This oil seal is part #92049-1037 (14/24/4.8).
Information i been told is remove the retaining bolt on clutch release shaft and seal should withdraw with shaft. Replace new seal and reassemble. All i need do now is find that seal here in the UK, which wont be easy. cheers.
Name:	vn750 bit - Copy.jpg
VN 750 A8 1992.
27000 miles.
to UK in 1996.
New for 2012.
Iridium plugs.
brake pads(Kyoto)
