44k and needs a clutch - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 17 (permalink) Old 11-07-2015, 07:40 PM Thread Starter
its not gone but just starting to slip under heavy load. already replaced the cable just to eliminate that first. I know theres a few threads on clutches and i have looked at them. is it worth going to kevlar or carbon fiber discs? i dont plan on running any exotic oil but i do ride hard. most shifts are in the 7500 to 8500 rpm range. really need pros and cons
85 700
coastered&shaved
uni filters
coil mod
KC's led turn signal boards
clear alternatives led tail light
Wolfies forward controls
vn900 seat
AGM Battery
Iridium plugs
willie and max bags
plexifairing 3
14 inch apes
97 75
parts bike for now
He was the sort of person who stood on mountaintops during thunderstorms in wet copper armour shouting "All the Gods are bastards."
goofin is offline
post #2 of 17 (permalink) Old 11-07-2015, 09:17 PM
Try moving the clutch arm on the motor 1 spline.might last a little longer ,gives ya some more adjustment
post #3 of 17 (permalink) Old 11-07-2015, 10:24 PM
Kevlar clutch with regular motorcycle oil. Get a kit with "heavy duty" springs.
Wet sand the metal plates or replace them too.
post #4 of 17 (permalink) Old 11-07-2015, 10:50 PM Thread Starter
amazon is showing a ebc kevlar kit with springs and steels for $136. ill invest in getting the tools just so i have them. probably drill the hub while im at it. did the 700 have the coffee grinder problem? i never had a issue until now.
85 700
coastered&shaved
uni filters
coil mod
vn900 seat
AGM Battery
Iridium plugs
willie and max bags
plexifairing 3
14 inch apes
97 75
parts bike for now
goofin is offline
post #5 of 17 (permalink) Old 11-07-2015, 10:57 PM
That's the set I'll be grabbing.
700 is the same design, so I'd imagine it had the issue? My 86 750 sure does, hah.
post #6 of 17 (permalink) Old 11-08-2015, 05:18 AM
I just replaced the stock friction discs. The metal discs were fine, and the springs were fine lengthwise. Not sure how I feel about heavy duty springs for street use. They make the clutch lever harder to pull, and put more stress on the clutch cable, lever pivot, The part that attaches to the bevel gear case, the actuating rod, and possibly other parts. More stress usually means faster wear. But, I tend to shift around 4000 rpm. I consider the Vulcan 750 a cruiser/touring bike, not a sport bike. 8500 rpm seems awfully high for a v-twin. In fact that is redline.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #7 of 17 (permalink) Old 11-08-2015, 01:29 PM
Man you're shifting before the motor makes any power.these bikes are made to rev.
post #8 of 17 (permalink) Old 11-08-2015, 01:39 PM
I put in the heavy duty springs, and didn't notice the clutch pull being any harder. I believe the "heavy duty" part is just that the springs use a better wire and are less prone to fatigue. You can see a photo of the two springs here:
https://flic.kr/p/3gEKUe
The "heavy duty" springs are a tad longer and thus have a bit more preload... But you'll notice they don't have more winds than the stock.
post #9 of 17 (permalink) Old 11-08-2015, 02:13 PM
Mine didn't have the coffee grinder issue till I put the clutch plates from my 86 into my 85.if I recall Wolfie's don't have the coffee grinder issue either
post #10 of 17 (permalink) Old 11-08-2015, 02:32 PM
I wonder if they changed the composition of the clutch plates from 85 to 86?
