Not shifting out of 1st after pulling motor - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
 4Likes
post #1 of 11 (permalink) Old 10-01-2015, 08:35 PM Thread Starter
ok guys i've been searching and i'm not sure that i'm wording it right as to what information i'm looking for, i have a 2006 Vulcan vn750
i recently pulled the motor to replace the stator, horrid design btw, anyway after getting everything back together and cleaned up i got to take a test ride and discover that it will not shift out of 1st gear i can drop to neutral and into 1st but thats it. please tell me its something stupid simple i'm new to working on bikes and id like to get it fixed asap cause im missing out on some nice cool days to ride .
btw nothing was dropped or smacked around,any info would be greatly appreciated, thanks in advance
Chief is offline
post #2 of 11 (permalink) Old 10-01-2015, 09:33 PM
I can't think of anything except the spring clip (internal) being out of place, problem on the shift drum (internal) or you weren't going fast enough for the Positive Neutral Finder to let it go into 2nd, or the PNF is gummed up and stuck.
Below a certain slow speed or stopped, the PNF only allows neut. and 1st gear.
post #3 of 11 (permalink) Old 10-01-2015, 10:05 PM Thread Starter
the spring clip and shift drum situation would require splitting the case right? it's just very confusing because before i replaced the stator it would shift fine , could it possibly be that the gear shift lever (peadal) is not positioned right? i'm just trying to think of anything that could be a stupid simple issue. i'm hoping that its just something along the lines of that
Chief is offline
post #4 of 11 (permalink) Old 10-01-2015, 10:51 PM
Does your shifter hit on the footpeg?if it's turned too high that might do it.wouldn't hurt to check
niterider likes this.
post #5 of 11 (permalink) Old 10-01-2015, 10:56 PM Thread Starter
i'll get back to you on that tomorrow evening, ive been scanning through the internet trying to figure out exactly what would cause the issue. Thanks guys for the info , ill check the shifter lever fingers crossed it's something simple
Chief is offline
post #6 of 11 (permalink) Old 10-01-2015, 10:57 PM
Hoping so as it shifted before
post #7 of 11 (permalink) Old 10-02-2015, 12:24 AM
Chucklehead
dragon159's Avatar
The spring clip in question would be under the hexagon cover rearward of the stator cover. It might require loosening and tilting the motor but then again may not. But I do have to agree that the problem may be the shift lever too high hitting the footpeg, the fact that it shifted before and goes between 1st and neutral tells me you shouldn't have to split the cases.
Chief likes this.
"Squirrel Bike" aka Jersey
Rat bike with a good PR agent
shaved and coastered
2 into 1 exhaust
rear 170 and front 110
custom dash with voltmeter
Spitfire windscreen
Plutonium plugs
More to come
dragon159 is offline
post #8 of 11 (permalink) Old 10-02-2015, 12:46 AM
Hopefully, Doc nailed it.
Someone here did successfully work on the spring clip with just the cover off and working through the holes inside. But it must have been like rocket surgery.
post #9 of 11 (permalink) Old 10-02-2015, 12:53 AM
I've done it,that's how I know
post #10 of 11 (permalink) Old 10-02-2015, 06:31 PM Thread Starter
Doc , i gotta hang my head in shame for a ridiculous mistake, it was the shifter was too high , just re adjusted the shift lever down a couple notches and raised it up on the center kick stand went through all the gears like a champ, gonna take it out for a road test just as soon as i can get a brak in the rain. Cant believe it was something so small, but i got it took care of , now if i can get through the rest of the weekend in one piece i'll be doing great. Thanks again Guys for all the help.
thtanner likes this.
Chief is offline
