Shifts between 1st and neutral, rolls freely in both.. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 10 (permalink) Old 09-10-2015, 09:17 PM Thread Starter
Hello All,
I know this isn't the proper way, or section, to do an introduction, but I need some help with a vn750 that I recently acquired from my brother and figured I would jump right in. I've been lurking and searching the transmission section of the forum meticulously for a few weeks now.
Little backstory: My brother picked the bike up from a dealer about a year and a half ago, rode it for about 6 months or so before it broke down, then it sat in a garage for about a year. He is now stationed in NC (Marines) and didn't want to deal with the bike, so I took it off his hands. Plan is to get it going again and do a hard tail, bobber build.
Symptoms: When it broke down, the bike was still running fine but would no longer move while "in gear", just revved.
I now have it here in my own garage and have begun tearing into it a bit. The bike will still shift into first and back to neutral (neutral light turns on and off accordingly), but will still roll freely while in "first" gear. Occasionally, while doing this, the bike will not go back into neutral from first (no light) or back into first from neutral. Rolling the bike a little bit usually remedies this and I am able to get it back to neutral with the light on.
I already pulled the oil glass site cover and checked the pawl and spring. It seems to be OK, moving back and forth as normal. I can also see it shifting from first to neutral. I took the clutch cover off and removed the springs, but have not yet pulled the plates out. From what I can see so far, they look OK. My main concern is the fact that the bike is still able to be rolled forward and back while it is in "first" gear. Something, somewhere is not grabbing or engaging like it should. I did notice that neither the basket or inner plates are rotating when the bike is rolled in first gear.
I'm hoping that someone here may know a quirk with these bikes that may be causing this and will make my day by telling me that I don't need to split the case. It's not that I won't, I just REALLY don't want to. Would much rather spend my time building the bike and writing/updating a build thread than rebuilding the engine.
Any help is more than appreciated.
2008 Yamaha R6 - Plenty of goodies and go fast parts.
New Project:
2003 Vulcan 750
- Final drive spline problems
The bane of my existence...
ProjectVulcan is offline
post #2 of 10 (permalink) Old 09-10-2015, 09:31 PM
Rear splines on driveshaft are worn out from not being lubed
post #3 of 10 (permalink) Old 09-10-2015, 09:35 PM Thread Starter
I was just reading about this. I wish I had been the one riding when it broke down, so I'm not taking so many shots in the dark. I'll take a look at driveshaft. Thanks!
New Project:
2003 Vulcan 750
post #4 of 10 (permalink) Old 09-10-2015, 10:10 PM
Chuck A.'s Avatar
Yep yep yep. 99% of the time.
Chuck A. is offline
post #5 of 10 (permalink) Old 09-11-2015, 12:02 PM
CAn't be a broken shifter rod? Seems like you might think it was in gear. Seems like even wiuth worn splines it would slip a lot before finally dying.
post #6 of 10 (permalink) Old 09-11-2015, 12:07 PM
Sounds like the final drive splines for sure.
If that's the case I have a spare final drive floating around. PM me.
post #7 of 10 (permalink) Old 09-15-2015, 05:02 PM Thread Starter
Update:
Finally had some time to tear the bike apart some more. Before doing so, I decided to start her up and see exactly what was going on when it's running. With the back wheel off the ground and the trans in first gear, the wheel actually started spinning. Brought a tear to my eye.
I was able to shift to second as normal, so, luckily for me, transmission seems fine. I had a suspicion that once I put the bike back down on the ground, with its weight on it, that the driveshaft would begin slipping. I was correct. Fine in neutral, but as soon as I clicked to first it began whirring and making a grinding noise.
Put it back on the center stand and tore the back end apart and found some nice, fine red powder.
So, our suspicions have been confirmed. I haven't completely pulled everything apart yet, but plan on doing so tonight. I called it quits last night, after getting the wheel and everything off, when the final drive didn't immediately separate from the drive shaft. Granted I didn't put too much effort into it, but any advice on separating the two?
Will update later, thanks for the help guys!
New Project:
2003 Vulcan 750
post #8 of 10 (permalink) Old 09-17-2015, 10:20 PM Thread Starter
Yep.
Had some time to tear the bike apart. Our suspicions have been confirmed. Looks like I will be needing a final drive and drive shaft. I've never been so happy to see stripped splines. I'm just glad I don't have to split the case open.
ID:	25777   Click image for larger version
New Project:
2003 Vulcan 750
post #9 of 10 (permalink) Old 09-17-2015, 10:24 PM
Yup that's the tell tale red rusty color of death there my fine feathered friend
post #10 of 10 (permalink) Old 09-17-2015, 10:32 PM
I bet once you get that fixed you'll check it on a regular basis. That's probably the #1 thing we suggest to new members is to check your splines. Lots of us have used the Moly 60 lube that's available at most Honda shops.
