Clutch plate orientation - had coffee grinder type symptoms and fixed now - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 6 (permalink) Old 08-23-2015, 01:19 AM Thread Starter
Exclamation Clutch plate orientation - had coffee grinder type symptoms and fixed now
I had coffee grinder type symptoms on my 99 vn750 and I was thinking about drilling the basket and putting in new plates. Also I was going to replace the basket if there were grooves worn in it.
I removed all the plates and steels. The frictions were like brand new... I put them back in exactly as they were and reassembled. Then I read the manual ... lol
The last (outer) clutch plate is supposed to be turned one notch in the basket... Mine were all lined up in the same groove.... I turned the outer one like the manual says to and voila! now my clutch woes are gone!
The previous owner replaced the clutch plates and never turned the last plate...
roger200x is offline
post #2 of 6 (permalink) Old 08-23-2015, 08:34 AM
just disassembling and reassembling the clutch can cure the coffee grinder for a time. It did on mine. it came back within 2 weeks. mine was assembled correctly.
the basket drilling, if I recall, is actually a kawasaki recommended procedure for curing the grinder, so they have researched it, and if they researched it, I am sure they did that on properly assembled clutches.
michiganteddybear is offline
post #3 of 6 (permalink) Old 08-24-2015, 10:58 PM Thread Starter
I wasnt saying it was a cure all fix... but I was making a suggestion to check if ppl didnt know to turn the last plate.
post #4 of 6 (permalink) Old 08-25-2015, 09:42 AM
it seems the root problem is the plates dry out when the bike sits. that's what the holes do, is provide quicker lubrication to the plates on startup.
post #5 of 6 (permalink) Old 08-25-2015, 07:02 PM
The clutch will still work fine if you don't turn the last plate.
I actually assembled mine without doing that and had no issues. I'm not really sure what the point in doing that is. Seems like it only help to make the clutch slip more as the plates wore out.....Perhaps it's to warn you of that?
post #6 of 6 (permalink) Old 08-27-2015, 11:35 PM Thread Starter
I agree it works fine but it works smoother and easier on my bike with it turned... just what I found
