bevel gear oil leak - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 7 (permalink) Old 07-26-2015, 03:57 AM Thread Starter
JETHRO's Avatar
bevel gear oil leak
hi just a quick question my bevel gear is leaking a bit from the rubber seal on facing side of bike.can this be replaced or is it as the manual states needs to be done by kawasaki mechanics ?
JETHRO is offline
post #2 of 7 (permalink) Old 07-26-2015, 05:09 PM
I did mine
post #3 of 7 (permalink) Old 07-27-2015, 03:40 PM Thread Starter
JETHRO's Avatar
bevel gear leak
ok, so did you just undo the four bolts and prise off the end cap ?
Vn 750 A2 1986 rebuilt engine, crank shaft, half casing,shell bearings,con rods,rear cylinder head,oil pump,water pump ,(had ceased bearing rusted up),tie bar upgrade,clutch basket drilled,front cylinder cam chains,toc springs,stator,shaved, rectifier,agm battery,solenoid ,starter motor (used) re-spray ongoing.
JETHRO is offline
post #4 of 7 (permalink) Old 07-28-2015, 10:37 AM
I don't remember.. I had the whole bevel gear off to replace all the bearings and seals while I was doing it.. I do remember that I didn't have any special tools.
post #5 of 7 (permalink) Old 07-28-2015, 04:04 PM Thread Starter
JETHRO's Avatar
bevel gear leak
ok well the book says its a complicated device and should not be tampered with but the oil leak is annoying,its not much but i would still like to cure it,i could buy used one off ebay but maybe have same problem ,do these tend to leak anyway or is mine unusual and where do i buy the seal from if i decide to tackle the problem.? thanks
JETHRO is offline
post #6 of 7 (permalink) Old 07-31-2015, 12:21 PM Thread Starter
JETHRO's Avatar
bevel gear leak
well it seems the end cap prises off and someone has put rtv sealer in there but it did not work so i have cleaned out old stuff and re-sealed it so maybe ok now i will leave for 24 hrs to cure and see
JETHRO is offline
post #7 of 7 (permalink) Old 08-01-2015, 01:42 AM
I used a 65mm O-Ring from a hardware store
