what am I missing, back axle - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 23 (permalink) Old 05-27-2015, 10:08 PM Thread Starter
Ok I went and got the 27 mm socket and used a impact wrench which made it a cinch to remove the axle nut, but now I can't get the axle past the muffler on the right side. Is there a trick to this or do I need to remove the muffler.
Grace and Peace to you!
Richard
mrseedsower is offline
post #2 of 23 (permalink) Old 05-27-2015, 10:29 PM
Mcneuby's Avatar
The Axle
I think removing the muffler is the easest way to go. You can just remove the support and maybe get enough movement that you can get it past the muffler if you want to try that.
New to me 2004 15k Last liscened in 2011. Stock as they come.
Mcneuby is offline
post #3 of 23 (permalink) Old 05-27-2015, 10:45 PM
JM2001's Avatar
Just remove the 2 retaining bolts below the passenger peg and push down on the muffler. That will give you enough clearance.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #4 of 23 (permalink) Old 05-27-2015, 11:08 PM
rsavant's Avatar
I removed the shocks and let the swing arm drop down. To me that was easier than removing the muffler.
"Katie"
2002 VN 750, stock except for accessories
Mustang seat
Super Bright LED brake strobe on trunk
About 25k miles
All drive train maintenance performed, drive shaft coupler replaced
Way more experienced at pulling VN 750 carbs than I ever wanted to be.
TOC ACCT rebuild kits installed
Pick up coil mod
Cooling system flushed, refilled with fresh coolant
Petcock rebuilt
VN sold, current steed Honda ST 1300
rsavant is offline
post #5 of 23 (permalink) Old 05-27-2015, 11:20 PM Thread Starter
well I hope that works in reverse. the axle is hitting on the bottom of the pipe.
Richard
post #6 of 23 (permalink) Old 05-27-2015, 11:21 PM
JM2001's Avatar
No need to remove the muffler. The axel bolt will slide over it.
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #7 of 23 (permalink) Old 05-27-2015, 11:23 PM
Yes, remove the bottom shock bolt and let the arm drop. It works better if you put a board under the center stand to get the bike a little higher.
post #8 of 23 (permalink) Old 05-28-2015, 12:06 AM
Yup pop the shocks loose thats the easiest way
post #9 of 23 (permalink) Old 05-28-2015, 10:46 AM Thread Starter
I have popped the shocks loose in fact they aren't on the bike at all. The rear tire isn't touching the ground and is as low as it can go (I guess) but the bolt is hitting the muffler. I had to stop last night but I will loosen the rear muffler mount and hopefully lift up on it to allow the bolt to come on out.
Richard
post #10 of 23 (permalink) Old 05-28-2015, 05:23 PM
Deviate's Avatar
If you took the shocks off the tire should be sitting on the ground. There's nothing to hold the swingarm up without the shocks. Unless you have the jack or something supporting the bike under the swingarm.
Leave it to me to NOT be fond of something then end up banging it.
Deviate is offline
