Gear shifter play - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 7 (permalink) Old 05-24-2015, 10:28 PM Thread Starter
dgulley21's Avatar
Gear shifter play
Just a general question about the play in the gear shifter itself. Is it normal to have play and on my bike the gear shifter can rub the frame while shifting down is it normal or ok?
dgulley21 is offline
post #2 of 7 (permalink) Old 05-24-2015, 11:41 PM
Crowley
crowley1027's Avatar
Try to push the shifter rod into and out of the engine.
Sit on the ground, on the left side of the bike. Grab the shifter, and try to push it into the engine, and pull it out of the engine.
If you have play, maybe an inch or two, I know what happened!
Let me know.
crowley1027 is offline
post #3 of 7 (permalink) Old 05-24-2015, 11:42 PM Thread Starter
dgulley21's Avatar
Exactly what it does...
post #4 of 7 (permalink) Old 05-25-2015, 11:07 AM
There is an internal Cir-clip which holds the shift rod outward....(beneath the damper gear).....
Cut a piece of hose of proper length, split it lenth wise, install over shift rod....thus holding shifter outward.
Mine has functioned as such for years.
post #5 of 7 (permalink) Old 05-25-2015, 11:22 AM Thread Starter
dgulley21's Avatar
Nice! Thanks
post #6 of 7 (permalink) Old 05-25-2015, 01:53 PM
I have the same thing on my second Vulcan. The hose trick works great! I'll probably repair it since I'm redoing the dampers this summer, though.
post #7 of 7 (permalink) Old 05-25-2015, 03:04 PM
Crowley
Yeah there are two circlips. Someone probably hammered the shifter on, like me, and knocked the circlip off. I'm going to try this hose trick though!
