your advice please - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 19 (permalink) Old 03-27-2015, 08:26 PM Thread Starter
your advice please
The bike I have has only 13,000 miles on it but it has sat for a few years. Do I still need to look at the drive shaft and relube it?
Grace and Peace to you!
Richard
mrseedsower is offline
post #2 of 19 (permalink) Old 03-27-2015, 08:29 PM
JM2001's Avatar
Yes
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #3 of 19 (permalink) Old 03-27-2015, 08:36 PM Thread Starter
isn't that harder than pulling the carbs
Richard
post #4 of 19 (permalink) Old 03-27-2015, 08:39 PM
uh, not by a long shot.
pulling rear wheel and drive to check the splines takes 30 mins, or less
michiganteddybear is offline
post #5 of 19 (permalink) Old 03-27-2015, 08:40 PM
JM2001's Avatar
X2 not hard at all.
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #6 of 19 (permalink) Old 03-27-2015, 08:41 PM Thread Starter
do I need a lift or can I take the rear wheel off with the center stand?
Richard
post #7 of 19 (permalink) Old 03-27-2015, 08:44 PM
No, it's a lot easier than pulling carbs. My 2003 was dry as a bone, but not worn, at 14,000 miles. Bet I could do it in 20 minutes now.
post #8 of 19 (permalink) Old 03-27-2015, 08:45 PM
heaney750's Avatar
use the center stand and u will have to lift the back a lil to get the tire out did mine bout 3 weeks ago
heaney750 is offline
post #9 of 19 (permalink) Old 03-27-2015, 08:50 PM
right, can be done on center stand, but clearance for pulling wheel is tight. put a 2x6 or similar under the center stand, will give you more than enough clearance.
*note* its wise to use a tie strap to go from behind the center stand to around the forks to keep the stand from trying to go back up to storage position while your removing the axle nut.
post #10 of 19 (permalink) Old 03-27-2015, 09:05 PM Thread Starter
what lube should I use?
Richard
