Engine removal / shaft drive question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 7 (permalink) Old 03-14-2015, 01:34 AM Thread Starter
I have to remove my engine and was wondering exactly how do I separate the drive assembly from from the final drive to get the engine out? Do I just pull engine forward and out or do I remove rear wheel and pull internal shaft out? Thanks.
gregoryrailroad is offline
post #2 of 7 (permalink) Old 03-14-2015, 01:57 AM
Just pull the motor from the shaft.have to wiggle it around a little but not that bad
post #3 of 7 (permalink) Old 03-14-2015, 02:01 AM
Chuck A.'s Avatar
I had a floor jack with a 1/2 piece of plywood mounted to it to roll the engine off the bike. I twisted the engine to the right as I pulled it forward just a bit, reached into the shaft tube with my fingers and pushed back on the shaft. Popped apart and the engine was lose from it. When doing this I had the bike on the center stand so when it went back together I could turn the back tire to help align the splines.
Chuck A. is offline
post #4 of 7 (permalink) Old 03-14-2015, 11:11 AM Thread Starter
Thanks guys. Well, here goes nothing. It's about to happen.
post #5 of 7 (permalink) Old 03-14-2015, 01:25 PM
It's not that bad an ordeal,actually kinda fun
post #6 of 7 (permalink) Old 03-14-2015, 06:41 PM Thread Starter
Well, I finally got it out. Wasn't as bad as I was imagining. Just a little finagling. Now on to the tear down to fix a 10 cent part.
post #7 of 7 (permalink) Old 03-15-2015, 02:55 AM
Well, now you have it out. Do everything you can afford to do before you reinstall. Better stator, new balancers, check valve springs, lap valves, rings, hone cylinder, etc. ??
smltownr is offline
