Where do i put the fluid in for the trany/final drive - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 5 (permalink) Old 04-08-2005, 06:08 PM Thread Starter
Newbie....just curious where i put the fluid in for the tranny and for the final drive. thanks
Vul750 is offline
post #2 of 5 (permalink) Old 04-08-2005, 06:14 PM Thread Starter
Re: Where do i put the fluid in for the trany/final drive
It is a 1986....
Vul750 is offline
post #3 of 5 (permalink) Old 04-08-2005, 11:43 PM
You remove the big nut on the side of the final drive. You drain it by taking out the smaller one on the bottom. Just fill it up to the threads of the hole.
Knuckles
'04 VN750
NE PA
Knuckles is offline
post #4 of 5 (permalink) Old 04-16-2005, 08:35 AM
Forum Faciliator
Red Baron's Avatar
When I change mine, I drain out the old, then put about 1/2 new in and spin the wheel to churn it around and clean out the old some more, then I drain it, put in the drain plug and fill as Knuckles has suggested.
Red Baron
Binghamton, NY
Alright Already, Lets Ride!!
Red Baron is offline
post #5 of 5 (permalink) Old 05-29-2005, 12:56 PM
Now what
Ironman's Avatar
In the Vulcan 750, like most motorcycles, the transmission is lubricated with the same oil as the engine. So you want an oil that is able to handle "shear" forces. Lots of choices, Shell Rotella-T works well.
*Newbie....just curious where i put the fluid in for the tranny and for the final drive. thanks*
'04 750A- and loving it!
VROC 13864
Using a Purlator One PL14610
Ironman is offline
